diesel usage per hour - SailNet Community
post #1 of 6 Old 03-26-2013 Thread Starter
AKAPeterc's Avatar
Send a message via Skype™ to AKAPeterc
I have just purchased a 2003 hunter 44DS which I will fly to soon to sail home approx 600nm. I am planning my journey allowing an estimate of 6nm/hour but there is a section of nearly 40nm were I will probably have to motor. Can any one give me an estimate of how much diesel fuel per hour that a Yanmar 56hp motor will use. Thank you
AKAPeterc is offline
post #2 of 6 Old 03-26-2013
chucklesR's Avatar
Re: diesel usage per hour
The rule of thumb is 1 gal per hour for every 18hp used - i.e. at 75% of RPM that 56hp motor is likely burning about 2 gal per hour.
Yanmar probably has power and fuel consumption curves available at their web site. Keep in mind it all depends on bottom condition.
I would not use 6 kts as your estimated speed especially over a 600 nm passage. A more reasonable allowance would be 5 kts based on experience of other cruisers (another general rule of thumb), and even that would depend on average wind speed where you are traveling.
chucklesR is offline
post #3 of 6 Old 03-26-2013
jimrafford's Avatar
A quick search found a passport 40 repowered w/ that engine averaged 1.16 gph @ 7.1 kts motoring between Newport RI and Miami on the ICW.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #4 of 6 Old 03-26-2013
Chuckles, not sure that rule of thumb is linear. Our 100hp Volvo burns approx 2gph.
Jeanneau 54DS
Minnewaska is offline
post #5 of 6 Old 03-26-2013
chucklesR's Avatar
I'm quoting John Vigor on that one. (The Practical Mariner's Book of Knowledge (page 71))
No experience above my Westerbeke 30 - which burned 1.12 gals at full RPM per the manufacturer.
post #6 of 6 Old 03-26-2013
Old as Dirt!
svHyLyte's Avatar
See Yanmar Fuel Consumption
On your 39' WL, I'm guessing you should average just shy of 6 Knots probably running at about 2800 RPM with a fuel burn of about 1.7 GPH. Considering the fuel capacity of that yacht, reportedly 51 gallons, assuming a 20% reserve your range under power along would be about 416 miles.
Despite the foregoing, do your own math with your observed RPM and actual boat speed with due consideration of tide/current effects as to VMG vs Burn Rate.
FWIW...
svHyLyte is offline
Turnbuckle usage brucedtyler Gear & Maintenance 3 02-27-2011 03:47 PM
measure amp usage QuickMick Electrical Systems 17 03-31-2010 08:24 AM
Diesel dies after approx. an hour bossk Gear & Maintenance 55 10-25-2008 07:32 PM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 10:54 AM
autopilot amp usage Brezzin Gear & Maintenance 4 01-02-2007 02:47 PM
