Exhaust Manifold Flooding with Cooling Water - Page 2 - SailNet Community
post #11 of 15 Old 04-17-2013
Re: Exhaust Manifold Flooding with Cooling Water
Overwhelming...I don't think so. A marine thermostat is usually set up as a "t" diversion valve, in which case the flow might be a problem. But if it was set up automotive style, slow engine = cold engine = flow shut down, so no flooding problem?
Seems like it would need some attention but the actual engineering of it, whichever way, shouldn't be impassible. Waterlift exhausts can be a mixed blessing, huh?
hellosailor is offline
post #12 of 15 Old 04-17-2013
casey1999's Avatar
I do not follow.
With most diesels, all the water that gets pumped by the raw water pump exists through the exhaust mixing pipe. So say you want to use an electric raw water pump. The pump needs to be sized to pump at a flow rate your mechanical pump would pump with engine at WOT. Now say your engine is at idle and your electric pump is pumping at the WOT rate. I would think you could risk back flowing into the exhaust manifold and engine cylinder.
Now say you want to shut the engine down. You would need to stop the electric raw water pump at the exact time (or maybe slightly before) the engine stopped or otherwise the cylinder would be flooded with water.
There is no practical way an electric water pump could work on a raw water cooled engine. The mechanical water pump running off the engine however self regulates in a beautiful manner. We are lucky for that.
casey1999 is offline
post #13 of 15 Old 04-18-2013 Thread Starter
I did some reading about electric raw water pumps. The most practical setup I found was one in which the pump was controlled by an oil pressure actuator -- oil pressure comes up, pump goes on, oil pressure drops, pump goes off.
But I've pretty much abandoned the idea, at least as a way to reduce the likelihood of exhaust flooding. For one thing, it introduces lots of extra complexity (which is inversely proportional to reliability). For another, as has been recently pointed out in this thread, a mechanical pump is somewhat self-regulated -- at cranking speeds, it doesn't pump very much, and by the time it's running at normal pumping speed, the exhaust gases are clearing the exhaust. And lastly, a good pump is quite a bit more expensive than I had anticipated (not to mention the cost of controls, wiring, hoses, etc.).
At this point, my plan is to install the Speedseal Life (assuming it's made for my engine), which will allow the pump to better tolerate a few seconds with shutoff suction (so I can open the seacock after the engine starts, rather than before).
Rusty123 is online now
post #14 of 15 Old 04-19-2013
I saw a mechanic quoted on another site as saying f everyone went dry exhaust and keel cooling , us mechanics would all be out of work`. Wet exhuasts are a major source of engine problems.`
Several friends, with water in the engine problems, went dry exhuast, and eliminated all such problems. I would never consider having a wet exhuast.
Brent Swain is offline
post #15 of 15 Old 04-19-2013
"I would never consider having a wet exhuast. "
So just what would you fit on a conventional sailboat with an auxiliary engine? Or wouldn't you have one at all?
Need used exhaust manifold Began77 Diesel 1 09-26-2012 07:48 AM
need exhaust manifold for my W30 captaineasy Gear & Maintenance 0 10-06-2009 05:08 PM
Need W 30 exhaust manifold captaineasy Diesel 0 10-06-2009 03:47 PM
Volvo MD-11C Exhaust manifold flydude3 Gear & Maintenance 1 04-14-2005 01:06 AM
MD11C Exhaust Manifold takwita Gear & Maintenance 1 11-10-2004 01:35 PM
