Yanmar 2gm20f heat exchanger - SailNet Community
post #1 of 4 Old 04-10-2013 Thread Starter
jerzy0129's Avatar
I just want to know how to reinstall the core heat exchanger. One side has two holes, on the shroud, and the other only has one. I just want to know which side goes towards the front of the engine, the side with two holes or one?
Any help would be greatly appreciated.
Thank.
jerzy0129 is offline
post #2 of 4 Old 12-18-2013
Re: Yanmar 2gm20f heat exchanger
Interesting problems:
I took my core out and took it to my local rad shop for cleaning.
Well he cleaned off the aluminum shroud like he dissolved it. No shroud any more
1000+ for a new one. Will the core work OK without the shroud.
Or
Maybe replace the shroud, where do the holes go?
What size are they
Anybody have some pictures of a 2gm20f core,
anybody ran a core without a shroud.
damorsoft is offline
post #3 of 4 Old 12-19-2013
christian.hess's Avatar
thats the problem with having "shops" do it
a vinegar bath in place after running would of done wonders without even taking it completely apart
when I did this on my 2gm I did not take the exchanger off, and when cleaning I used mild cleaners and vinegar baths in place...then painted and called it good
Im sorry this happened to you...
I beleive the innards need to be complete for flow to be correct...
christian.hess is offline
post #4 of 4 Old 01-03-2014
Have you ever had your core out? I am looking at repairing mine and have found a shop who can redo the aluminum sheath. Still I am not sure how many holes are in the sheath and what is the diameter of same holes.
Yanmar Heat Exchanger Hunterdon31 Diesel 6 06-26-2015 11:29 AM
Heat exchanger Flfishindude O'Day 5 08-17-2013 09:07 AM
Yanmar Heat Exchanger/Exhaust Elbow CapnRon47 Gear & Maintenance 7 11-06-2012 08:04 PM
Yanmar 2GM20F Heat Exchanger arf145 Diesel 3 05-10-2011 03:43 PM
Yanmar Heat Exchanger Problem? AlanBrown Gear & Maintenance 5 05-06-2008 10:00 PM
