2gm 13 Yanmar external oil line "HELP"!! - SailNet Community
post #1 of 3 Old 04-16-2013 Thread Starter
First String
Good morning,
So last Sunday I took some folks out sailing on my C&C 30 Mk1 "675" and had just shut down the engine when I heard the engine low oil pressure buzzer. I had jumped thru the companion way removed the steps to find oil "Lots of oil" in the bilge?
After freaking out a bit, I continued under the main sail and sailed the distant back to the marina. The tide and apposing would not allow a smooth landing alongside the face dock. I called the Tow-US. i pay them once a year right? Anyway, After I sent the passengers along their way. I began to look for the leak. I found it on the inside of an external oil line on the back of the engine. I think it sends oil to the valve train from the block. It has an 8mm and a 12mm banjo bolt with 4 brass washers.
Here is my question: Does the starter have to come off to replace this line?
The line broke after I muscled with it for 30 minuets’ or so, trying to get it off. It finely broke in half and I removed it. Thanks in advance for your help.
ltgoshen is offline
post #2 of 3 Old 04-16-2013
Courtney the Dancer
jrd22's Avatar
Re: 2gm 13 Yanmar external oil line "HELP"!!
We had to remove the starter on a 3GM if I remember correctly. The most difficult part was holding all the crush washers in place while holding the line and fiddling with the bolts. It was a two person job for us, but we didn't have good access to the starboard side of the engine. The new line appears to be something other than just steel so hopefully it won't corrode like the original.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 3 Old 04-16-2013 Thread Starter
First String
Well there is just me and there is no room to work. I can come in from the front on the engine at the companionway steps and lean over the motor and get in from the starboard locker. But I, sure ether way the starter will have to come off? Right?
ltgoshen is offline
Hans Christian "Christina" line of boats sailway Boat Review and Purchase Forum 11 11-08-2015 01:09 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Shore power line "sticky" jklingenstein Gear & Maintenance 4 07-31-2012 02:45 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
