Restart is hard after the winter - SailNet Community
 1Likes
post #1 of 17 Old 04-18-2013 Thread Starter
2nd mate
Unhappy Restart is hard after the winter
Hello,
I have a Kubota 3 cyl 21 hp.
The filters and oil are all changed as it should be.
The problem is that I can't start the engine.
It turns over nicely, but the glowplugs don't stay on long enough.
When I measure the voltage on the glowplugs, it reads 10 or 11 volt and dropping slowly. The relais shuts off, before i release the glowplug switch.
The starting battery reads 12,7 volt at rest and 10 volts when glowing or cranking.
This starting battery is charged by a good 4-stage charger from shorepower.
Do I need new battery or new relais or is it someting else?
bartvdv is offline
post #2 of 17 Old 04-18-2013
BarryL's Avatar
Re: Restart is hard after the winter
Hey,
If your starting battery is at 10 volts when USED (glow plugs and / or cranking the engine) either it is discharged or just dead. If it reads 12.7 at rest I think the battery is just shot. Do you know how old it is?
Can you 'borrow' a known good battery and use that as a test?
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #3 of 17 Old 04-18-2013
Tartan 27' owner
CalebD's Avatar
Also, do they have wd40 in Belgium?
You can use wd40 as a starting fluid with diesel engines.
Squirt some on the air intake before cranking.
Ether is not recommended for starting diesels.
Everybody has one:
CalebD is offline
post #4 of 17 Old 04-18-2013
Have a go and DIY .....
Originally Posted by bartvdv View Post
Hello,
Just had the same problem .
Lucky for me the engine has not yet been fitted .
But it turned out to be the fuel cutoff solenoid.
Seems if it is not working the power can not pull back a small pin.
Hence the pin stays out and stops the fuel starting the engine..
It was Not easy to find that out I can tell you...
macwester26 is offline
post #5 of 17 Old 04-19-2013 Thread Starter
2nd mate
I do have WD40, 'i'll give it a shot'.
Today i will try to find a known good battery (or buy one).
bartvdv is offline
post #6 of 17 Old 04-19-2013
fryewe's Avatar
I think macwester is on the mark here. If you have a fuel cutoff valve (many small diesels do but many don't...I'm not familiar with Kubota) and the voltage drops too low the fuel cutoff solenoid will not stay open to allow fuel to flow.
If the voltage starts at 12.7V with no load your battery it needs an equalizing charge at a minimum. If after equalizing the battery the open circuit voltage is still less than 13V or if the voltage is higher but falls rapidly when the glow plug circuit is energized you need a new battery.
Good luck.
fryewe is offline
post #7 of 17 Old 04-19-2013
BarryL's Avatar
Hey,
I have a 3 cyl Universal Diesel on my boat, which is based on a Kubota tractor engine. The engine stop lever is mechanical, there is no solenoid involved.
Barry Lenoble
Mt. Sinai, NY
BarryL is offline
post #8 of 17 Old 04-19-2013
12.7 volts at rest, 24 hours since the last charging, would be a 100% perfectly good "12" volt battery.
"It turns over nicely" seems to confirm this.
hellosailor is offline
post #9 of 17 Old 04-20-2013
JimsCAL's Avatar
Did you change the fuel filters? If you did and got air in and didn't bleed the system, it won't start.
MarkSF likes this.
JimsCAL is online now
post #10 of 17 Old 04-24-2013 Thread Starter
2nd mate
Fuel is clear of air, seems OK.
i tried my house battery to start the engine, but the effect was the same: the reading voltage on glowplugs is only 10,5 V (maybe the house battery is also shot...)
I also bridged the glow plug relais manually, but the effect was the same.
I tried also the WD40, to no avail.
I ordered a new battery to sum things up :-)
bartvdv is offline
Tags
kubota , relais , starting
She's on the hard now for the winter. Nazdrowie General Discussion (sailing related) 10 10-12-2012 01:08 PM
cannot get engine to restart boblivingston Pacific Seacraft 13 05-14-2011 05:05 AM
PSC's on the hard for winter - Drain hole in rudder? MC1 Pacific Seacraft 5 11-06-2009 08:52 PM
Restart Diesel After Layup TXS-ALAMO Gear & Maintenance 3 09-13-2006 07:23 PM
Corpus Christi harbor reopened, refineries restart (RedNova) NewsReader News Feeds 0 06-04-2006 09:15 PM
