Impeller...when is 2" the same as 2.25"? - SailNet Community
post #1 of 3 Old 04-22-2013 Thread Starter
deltaten's Avatar
Send a message via Yahoo to deltaten
Pulled the RW pump this past w/e. Seems the JABSCO impeller needs replaced. In trying to source one, I find that they want tip-to-tip diameter. Well! I measure from tip-to-what's-left-of-tip and get near to 2 1/4 inches.
Do these things "grow", or is it a case of "close is enuff" when it comes to ultimate diameter? Seems ta be no 2 1/4" impellers listed.
I called the local (to home port) marina and found they had one 2"x7/8"X1/2" #1 (pin shaft) for only $46.93! Guess I'll hafta go in and hold one to the other and check. Once satisfied, I'll source via Amazon or elsewhere and get the spare.Since I'll need the one by the coming weekend; I'll justhafta bite the bullet and pay the price
TIA,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #2 of 3 Old 04-22-2013
Learning the HARD way...
eherlihy's Avatar
Re: Impeller...when is 2" the same as 2.25"?
I believe that the 2" is the size of the cavity of the pump housing. The impeller measurement, from tip of the blade to tip of the opposite blade, should be slightly larger than the cavity in order for the blade to form a seal against the housing and the cam.
eherlihy is offline
post #3 of 3 Old 04-22-2013
Senior Smart Aleck
jameswilson29's Avatar
I suggest you go about this from a different angle. Gather the information about your pump, run it in Google with "replacement part" or "replacement impeller" and you should be directed to exactly the right size.
jameswilson29 is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
