Fuel smell my Watkins 27 - SailNet Community
post #1 of 11 Old 04-28-2013 Thread Starter
We just purchased a 27 foot Watkins Sailboat with a Yanmar inboard Diesel engine. After taking the boat out, the fuel smell is really strong, especially at night when we are sleeping on the boat. It does not seem like a leak. I have seen so posts talking about better ventilating the cabin. Any suggestions on how best to do this? Also, I've also seen a couple of suggestions on soaking up the fuel in the bilge? Any other suggestions? I am worried about the health effects, thank!
Changernyc is offline
post #2 of 11 Old 04-28-2013
Re: Fuel smell my Watkins 27
What makes you think its not a leak? I'd go over all fuel components from the tank to the engine while the engine is running and while its off to ensure there are no leaks. Could it be residual fuel in the bilge from a spill? Pumping the bilge dry and seeing if any fuel makes its way back in should tell you if its leaking from somewhere or not.
Racecase is offline
post #3 of 11 Old 04-28-2013
Tartan 27' owner
CalebD's Avatar
Get a Bilge Boom oil absorbent thingy and let it float around in your bilge (~$10). Toss it out once it gets to be really disgusting.
Get dawn dish detergent and scrub out the bilge, engine compartment and everywhere.
Get the white oil absorbent pads (about 1' x 2') and lay them out under your engine and fuel tank. If there is a leak you will find it.
The smell of diesel is worse than the smell of gasoline in my opinion. Not worse than head stink but the two combined are the pits.
Everybody has one:
CalebD is online now
post #4 of 11 Old 04-29-2013
Odds are you do have a small leak or unintended vent somewhere. Find it, could be dangerous. Where is the tank intentionally vented? That could be it.
Jeanneau 54DS
Minnewaska is offline
post #5 of 11 Old 04-29-2013
chucklesR's Avatar
Even if you see no fuel in the bilge it could still be fuel laying about under the engine. Swish a couple paper towels up under there with a thin stick as a check.
Hot diesel can really vapor up and stink.
It's not explosive, it's just a stick pit.
chucklesR is offline
post #6 of 11 Old 04-29-2013
One of None
deniseO30's Avatar
Fuel tank may have pin holes and if it's sitting on a wood platform the wood could be soaked and you would not see it.
My last project!
deniseO30 is offline
post #7 of 11 Old 04-29-2013
I need to edit my dangerous comment, I thought we were talking about gasoline for some reason. Diesel is not going to ignite, but doesn't evaporate well either. Even if there was a spill that was wiped up, the residue can continue to smell. Gasoline will eventually all evaporate.
Jeanneau 54DS
post #8 of 11 Old 04-30-2013
Tartan 27' owner
CalebD's Avatar
This is another reason why I like my 45 year old Atomic 4 gasoline engine. If any fuel leaks out (usually very little or none) it evaporates pretty quickly. If I have a major fuel leak I will have a major problem but small leaks don't amount to a stinky smelling boat. The smell of diesel fuel can be pretty pervasive.
That said I wouldn't mind having a boat with a nice diesel engine in it.
Everybody has one:
post #9 of 11 Old 04-30-2013
Originally Posted by CalebD View Post
....If any fuel leaks out (usually very little or none) it evaporates pretty quickly......
True, but evaporated gasoline can be the perfect air/fuel ratio for ignition.
Jeanneau 54DS
post #10 of 11 Old 04-30-2013
Tartan 27' owner
CalebD's Avatar
It may blow up but it doesn't stink!
Everybody has one:
Tags
diesel , fuel smell , health effects , ventilation , watkins
Going to look at a Watkins 27..... deltaten Watkins 45 01-01-2016 12:14 PM
Watkins 33 garyp Boat Review and Purchase Forum 3 07-13-2013 07:49 PM
Watkins 32-33 garyp Boat Review and Purchase Forum 0 11-20-2004 08:27 AM
watkins 32 KenD Boat Review and Purchase Forum 0 04-15-2002 04:08 AM
Watkins 29 pjaarch Boat Review and Purchase Forum 0 04-07-2002 03:52 PM
