Gotta find my fuel leak... - SailNet Community
post #1 of 8 Old 05-05-2013 Thread Starter
blutoyz's Avatar
Well...
The fun starts on my cheap boat
I started the engine on the hard last week to make sure it ran before splash and yesterday found a puddle of fuel on the top of the tank. I have to go today to finish the launch prep so I will wipe off the tank, fire it up again, and see where the leak is.
Let's hope for an easy fix
P.S - The good news is it fired right up
blutoyz is offline
post #2 of 8 Old 05-05-2013 Thread Starter
blutoyz's Avatar
Re: Gotta find my fuel leak...
False alarm...
That fuel could have been there since the fill up in the fall. I will have to keep and eye on it but did not see any leaks
blutoyz is offline
post #3 of 8 Old 05-05-2013
Freedom 39
FarCry's Avatar
Unless it's a really deep pool, it should have evaporated. How much diesel are you seeing? A cup? A quart?
FarCry is offline
post #4 of 8 Old 05-06-2013 Thread Starter
blutoyz's Avatar
I don't even think there was a cup there, a puddle 1/4" at the deepest point 3-4" around. It soaked right up with some paper towels
blutoyz is offline
post #5 of 8 Old 05-06-2013
Fuel rarely leaks "up" from a tank. OTOH fuel inlets and filler hoses have been known to leak, and vents or access ports for the gauge float may overflow if the tank has really been filled to the top. I'd expect fuel from "last year" to have evaporated over the winter, even diesel fuel.
hellosailor is offline
post #6 of 8 Old 05-06-2013 Thread Starter
blutoyz's Avatar
My money is up throught the gauge sending unit. It is getting warmer so maybe the vent is clogged. I will pull the cap and see if there is pressure to be safe
blutoyz is offline
post #7 of 8 Old 05-06-2013
Freedom 39
FarCry's Avatar
Has the fuel leak come back since you wiped it up? Can you run the engine for an hour or more to lower the fuel level and see if the leak stops? You said you noticed the fuel after running the engine. Could it be coming from the fuel return line?
FarCry is offline
post #8 of 8 Old 05-06-2013 Thread Starter
blutoyz's Avatar
I will post again next week after some more maintenance time
blutoyz is offline
Fuel Leak? mikefossl Diesel 2 02-17-2012 11:23 PM
Pressurizing interior to find a leak L124C Gear & Maintenance 24 06-24-2011 11:35 AM
Westerbeke 30 Fuel leak TPynckel Diesel 0 12-19-2010 05:44 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 12:41 AM
Fuel Tank Leak silversea Gear & Maintenance 1 02-13-2002 04:05 AM
