Ford Lehman 120 - SailNet Community
post #1 of 2 Old 05-11-2013 Thread Starter
Ford Lehman 120
I have been trying to locate the tachometer sensor on my Ford Lehman 120 with no success. One mechanic mentioned that some tachs have a magnetic sensor on the flywheel. Another source mentioned that it typically is attached to the alternator.
Also I have discovered a wire near the alternator that comes off the port side engine block off of some type of sensor. I assumed this was originally attached to the alternator post but when I connected it there it overrode my engine kill switch at the helm. Any ideas as to what this wire is and where it should be attached. I am attaching a picture showing the alternator, the wire and the sensor below on the engine block.
Any suggestions will be much appreciated.
Craig Robelen
561-350-8983 cell
Craig Robelen is offline
post #2 of 2 Old 05-11-2013
Re: Ford Lehman 120
Google American Diesel Corp in Va. The owner of the place, Bob Smith, is the grand daddy of the marinized Ford Lehman. He knows more about the engine than the next top 5 diesel mechanics put together. When it comes to the Lehman, he can diagnose problems over the phone better than most mechanics can sitting in your engine room.
Catalina 34
chuck53 is offline
Ford Lehman Oil Analysis **Help! S/V Arabesque Diesel 5 02-03-2012 08:42 PM
oil in coolant Ford Lehman PatrickAlaska Diesel 8 11-13-2011 10:59 PM
ford lehman 192d fcsob Morgan 2 12-23-2007 11:48 PM
ford lehman 192d fcsob Gear & Maintenance 1 12-11-2007 07:03 PM
Ford Lehman Engine TSteele65 Gear & Maintenance 3 04-06-2007 07:54 PM
