New Owner Transmission Question - SailNet Community
post #1 of 5 Old 05-12-2013 Thread Starter
Big day for baseline maintenance of our newly-acquired O'Day 322. Adjusted valve lash, changed coolant, engine oil and trans oil. I ran into a big "ponderable" while changine the transmission oil. I have the KM2P transmission which according to everything that I have seen is supposed to have SAE 30 engine oil in it. Mine had ATF in it. Do we have any opinions as to the extent of the damage this could have caused? There is no telling how long the ATF fluid had been used...
Invictus322 is offline
post #2 of 5 Old 05-12-2013
Senior Pirate
TropicCat's Avatar
Re: New Owner Transmission Question
Good question, get that stuff out of there immediately. If the transmission cone isn't slipping now, I would say you're OK.
I made this mistake the first year I owned my catamaran, which has a pair of Yanmars with the same transmission as your boat. I drained flushed and refilled with SAE 30, and she's worked fine ever since.
Tropic Cat
TropicCat is offline
post #3 of 5 Old 05-12-2013
The safest bet is to follow what the manufacturers manual recommends down to the letter. Older manuals cannot always anticipate future standards such as the Dexron ATF standard. Read the labels very carefully of whatever you buy to make sure it conforms to the requirements. I was surprised by the many variations of ATF out there
engineer_sailor is offline
post #4 of 5 Old 05-12-2013
ScottyG24's Avatar
obviously follow the manufacturers recommendation but you should be fine. as an example i race a single seat open wheel formula car. while the tranaxle manufacturer recommends a 30w gear oil some guys run Dextron (trans oil) or a 7W gear oil to reduce mechanical resistance as both are much thinner viscousity. we run the engines at 7000 rpm and cars at about 120mph on the straights and the trannnys hold up so I think youll be fine as in yr Oday the trans is really living a sedate life comparatively
ScottyG24 is offline
post #5 of 5 Old 05-12-2013 Thread Starter
Thank you everyone for the feedback...when I "saw red" while pumping it out, I felt sick to my stomach...
Yanmar transmission dipstick question arf145 Diesel 12 08-21-2014 06:46 AM
transmission question almostbroke Gear & Maintenance 10 09-17-2012 09:56 AM
Another New Pearson Owner Question kjones Pearson 3 09-29-2011 06:31 AM
Pearson 33 Owner/Question AerieWestRiverMD Introduce Yourself 1 03-12-2011 04:38 PM
Oh No! New Owner with another Diesel Bleeding/Fuel Question arf145 Gear & Maintenance 23 09-20-2007 11:19 PM
