Yanmar 3g starting - SailNet Community
post #1 of 5 Old 05-14-2013 Thread Starter
Yanmar 3g starting
The last diesel engine i operated was on a Bradley platform. So this little tractor engine on a sailboat is a different beast.
I started the engine for the first time today and all went well. I just had it serviced by a pro who assures me all is well. But i want to be sure im doing this right.
There seamed to be a bit more smoke then i anticipated and it does not shut off with the key it just keeps on running. I finally pulled what i had at first thought was a choke and the motor stopped running. so was that a decompression type thing? and how much should this engine smoke? Oh the motor is about 22 years old.
Also it did not really smoke that much just more then i thought it would.Oh and on the control panel for the engine there is a toggle switch that has three positions. bottom, center and a top momentary. Nothing seamed to happen regardless of where it was. The lettering has either worn off the panel or in some cases the writing is in french. Anything will be helpful, Thanks
huntermj is offline
post #2 of 5 Old 05-14-2013
Re: Yanmar 3g starting
What you pulled was the fuel shut off. You need to stop the engine before turning off the key or you can fry the alternator.
The toggle switch is for a backlight, I think
CLOSECALL is offline
post #3 of 5 Old 05-14-2013 Thread Starter
Yikes, Glad i asked, Thank You, Jim
huntermj is offline
post #4 of 5 Old 05-16-2013
Badger Sailor
MSN2Travelers's Avatar
Arrow Re: Yanmar 3g starting
Here is the panel from my Yanmar 3GM30
This the toggle switch you talking about? It turns on the panel back lighting for the guages. I believe that switch is powered when the nav lights are on.
Paul
`99 Beneteau Oceanis 352, #282 WiTCHCRAFT
Milwaukee, WI
Sailing Lake Michigan and the Great Lakes
MSN2Travelers is offline
post #5 of 5 Old 05-17-2013
JimsCAL's Avatar
The toggle switch on my 3GM30F is for checking the alarm lights. The high temp light in particular since it doesn't light before start up like the low voltage and low oil pressure lights do.
JimsCAL is offline
Yanmar not starting doug1957 Gear & Maintenance 7 10-09-2012 10:07 AM
3GM yanmar hard starting sailor5017 Diesel 3 04-07-2011 09:41 AM
Trouble Starting my Yanmar 1GM bullrunner Hunter 2 11-14-2007 04:06 PM
Trouble Starting my Yanmar 1GM bullrunner Gear & Maintenance 3 04-25-2007 05:16 AM
Yanmar starting problems... marinesniper Gear & Maintenance 2 12-20-2006 12:45 AM
