removing fuel injector pump - SailNet Community
post #1 of 5 Old 05-22-2013 Thread Starter
trantor12020's Avatar
Working on plan to remove the Timing cover to replace leaking gasket on my Yanmar 2 GM20F engine. Question is, is it difficult to remove the injector pump? Any precaution to take? Any chance of some parts going out of alignment?
Advise appreciated.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #2 of 5 Old 05-22-2013
Re: removing fuel injector pump
Advise appreciated.
No experience with Yanmar, but with VW, whose pump rotated, like a distributor, in the block. I would scribe a mark connecting the pump and the block for re-installation, assuming nothing had turned or moved.
Paul T
dabnis is offline
post #3 of 5 Old 05-22-2013
old guy :)
rikhall's Avatar
With ours it was just taken off - replaced the gasket and two "O" rings and put it back on.
Nothing to re-align.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #4 of 5 Old 05-22-2013
fryewe's Avatar
You have to remove the governor linkage first. Also, the injection pump is shimmed at the mating surface to define the size and timing of the pump flow with the piston/valve timing. Do not lose these shims! The pump fits metal-metal and the inlet and outlet piping are connected with beveled threaded fittings. There are no gaskets or o-rings.
If you pull no gears the timing will not be affected.
The hardest part should be re-attaching the governor linkage fork to the rack on the pump.
Do you have the service manual? If not, get it. Worth every penny.
Good luck.
fryewe is offline
post #5 of 5 Old 05-25-2013 Thread Starter
Ok fryewe, i got to be careful with the link fork. Thanks.
Ken
Help! Leaking Injector Pump Classic30 Diesel 87 03-31-2014 12:29 PM
Perkins 4-108 Fuel Injector Pump Leak Letrappes Diesel 18 04-22-2013 03:50 PM
Fuel Injector Pump leaking Axle2121 Gear & Maintenance 18 10-02-2012 03:55 PM
Fuel leak in injector pump RussT1950 Diesel 8 04-12-2010 07:28 PM
Faulty fuel injector pump or? Eleanna Gear & Maintenance 2 10-24-2006 10:19 PM
