2GM 15 dies when I put it in Fwd - Page 2 - SailNet Community
 2Likes
post #11 of 29 Old 05-23-2013
One of None
deniseO30's Avatar
Re: 2GM 15 dies when I put it in Fwd
As was told to me. "Diesels need air, clean fuel without air in it, and they will run forever" So. when was the last time your filters were changed?
My last project!
deniseO30 is offline
post #12 of 29 Old 05-23-2013
Since the motor runs fine in reverse, but stalls in forward...I'm suspecting something is going on in the transmission since that's the only thing that has changed...
1983 Lippincott 30 s/v Red Horizon
Regent Point Marina Topping, VA
RedHorizon is offline
post #13 of 29 Old 05-23-2013
Freedom 39
FarCry's Avatar
Originally Posted by ltgoshen View Post
Itís been Getting harder and harder. When I first got the boat, Last February, we noticed that it was a pain in the &*^% but we learned to use it. Last month we blue the external oil line and had to change it out. After that, it has become so bad that it makes tight quarter maneuvering very risky.
Does the engine smoke when you put it in forward? How about when you add throttle to keep it running? How big is your alternator and are your batteries fully charged? I ask because I put an 80 amp alternator on my 2QM15 and if the batteries were low, it was hard to keep it running at low RPMs in forward. Reverse didn't seem as bad, probably a lower gear ratio in transmission.
FarCry is offline
post #14 of 29 Old 05-23-2013 Thread Starter
First String
Yes id does smoke some now when I rev it up? Is this a sign it needs to be blead out?
ltgoshen is offline
post #15 of 29 Old 05-23-2013 Thread Starter
First String
Also, the rev gear has like half speed as Fwd and has almost no thrust. So i only have problems under a load.ie Forward. And yes it smokes when I throttle hard but then clears up
ltgoshen is offline
post #16 of 29 Old 05-23-2013
A little smoke that appears when you throttle hard, but then disappears quickly is normal.
post #17 of 29 Old 05-23-2013 Thread Starter
First String
So at this point I should check the linkage for full travel.and bleed the injectors?
egent likes this.
ltgoshen is offline
post #18 of 29 Old 05-23-2013
davidpm's Avatar
I have heard this recommendation before but am puzzled.
If the boat is running doesn't that bleed the injectors.
IE what air can be left if the engine is running?
I understand the concept of bleeding the fuel line if the engine will not start. If enough fuel doesn't get to the injectors it will not start.
Wait I think I got it.
It is not that their is air trapped in the line, it is that there is a small leak that is continuous that is making the mixture a little too lean that only shows up at idle.
"Bleeding" is really effectively tightening and getting rid of that leak.
Is that it?
No with that kid of pressure the fuel would leak before air would get in.
davidpm is offline
post #19 of 29 Old 05-23-2013
davidpm's Avatar
Anything that causes loss of power should be considered.
One thing that can cause loss of power is some constriction in the exhaust.
A clogged mixing elbow is a very common issue.
Many exhaust systems are not designed that great to start with and any constriction will put it over the edge.
davidpm is offline
post #20 of 29 Old 05-24-2013
OK, you mentioned just now that you have a folding prop. That partly explains why you get revs in reverse, because some of those props are pretty useless going backwards and do not stay fully extended. At idle in reverse it is probable that the blades are hardly open at all. Therefore there is not as much load on the engine in reverse.
So, if the shaft turns freely and is not moving forward under load to put stress on the gearbox or some other part of the shaft log, it seems simply a case of the engine not making power. Often a diesel with some air in the fuel system will start and run, but never make full power. It could be as simple as that, or as others suggest could be low compression (you hope not), injection timing out of whack (easy fix, if you have the book on it), clogged air intake (even easier), clogged exhaust elbow (easy enough but dirty job).
Just work through it starting with the easy jobs first.
arvicola-amphibius is offline
YSM 12 dies after starting ggrizzard Diesel 2 06-29-2009 12:59 AM
Engine dies cdisney Atomic 4 9 11-20-2008 08:56 PM
Dies, wait, restarts kpdii Atomic 4 9 08-20-2008 01:37 PM
Engine dies, what would you do..... DrB Seamanship & Navigation 26 08-19-2007 09:40 PM
Engine Dies HELP!!! lauralee Gear & Maintenance 19 09-01-2003 07:43 AM
