2GM 15 dies when I put it in Fwd - Page 3 - SailNet Community
 2Likes
post #21 of 29 Old 05-24-2013 Thread Starter
First String
Re: 2GM 15 dies when I put it in Fwd
1) Plenty of water spitting out of the back.
2) 2200 rpms tied to the dock lots of prop wash. seams to be strong engine. " NOT" a loss of power problem?
3) my problem is at low rpms, while trying to menover away from the dock in the marins. It tryes to stall at low rpsm just as I put it into gear.
4) someone told me the 2gm are known for shifting where they want to. That means it will not let you slam it into gear. Thats the way mine is. I can only go into gear if I have it set around 9000. any more at will not take gear. any less than that it stalls out. My problem is I that balance is out of wack? I will work on it today to see if there is a dirty prop or somthing ristricting it up.
ltgoshen is offline
post #22 of 29 Old 05-25-2013
When you do get it away from the dock and warmed up, run it for a while at full throttle. The 2GM series should pull AT LEAST 3000 rpm in forward gear if they are making power and you have the right prop, assuming that it is a clean prop to start with. I don't have the book with me, but recall the maximum RPM is about 3300, so less than 3000 would indicate a problem - even with an old engine. A few minutes at full throttle will not hurt it - in fact Yanmar recommend that you do this occasionally - I run mine up to 3000 rpm for three minutes in every hour (it will pull 3200 if I want it) and always just before returning to the mooring. I have always done so with all my diesels, and never had any problems with excessive oil consumption or power loss as a result.
After I give it this high power burst of three minutes, I throttle it down in 300 rpm increments back to the normal 2100-2200 rpm which seems to be its 'sweet spot' for cruising and which gives me close to hull speed. Sometimes I will feel around the top of the thermostat housing to get an idea of whether it was getting too warm. I know this is a bit un-scientific, but mine has no water temperature gage and I don't want to wait for the buzzer to tell me it has already over-heated. Being raw water cooled it never gets very hot.
I do not rev it before shutting it down, just idle it for a few minutes.
arvicola-amphibius is offline
post #23 of 29 Old 05-25-2013
fryewe's Avatar
Are your shift/fuel levers completely independent or do they share a common shaft?
fryewe is offline
post #24 of 29 Old 05-25-2013 Thread Starter
First String
independent
ltgoshen is offline
post #25 of 29 Old 05-25-2013 Thread Starter
First String
2500 rpm's is the highest it will run up in forward gear.
ltgoshen is offline
post #26 of 29 Old 05-26-2013
2500 rpm is not enough, but it may not be a lack of power, it may be something as simple as throttle cable rigging.
I suggest that you get it idling at 900 to 950 rpm, if that is where it will shift into gear smoothly. Get someone to then put it into gear while you watch for any movement of the throttle lever where it goes on to the fuel control unit. It is just possible that some kind of interference or movement is happening when you go in one direction but not the other, or as I said earlier, the folding prop is masking the problem in reverse because there is less resistance.
In theory the idle stop should prevent RPM going below whatever you have set the idle at, but maybe the stop screw has gone missing? My 2GM sometimes stalled when cold and going into gear at 900 rpm. Just half a turn of the idle stop brought it up to 950 rpm and since then it has been OK.
At the other end of the scale, i.e. full throttle, make sure that the throttle lever is moving through its full range to the WOT position. I am not sitting in front of my engine, so I can't remember if there is a visible stop at the high end. If not, you may have to drop the throttle cable off while you move the lever by hand to compare the range of movement.
Sometimes it can be the simplest thing. You can only hope.....
The Following User Says Thank You to arvicola-amphibius For This Useful Post:
ltgoshen (05-27-2013)
post #27 of 29 Old 05-27-2013 Thread Starter
First String
I,am what happened, but the problem wen away. I sailed out the Shipping channel, Motoring like the first 4 mile because of a head wind. Once in open water, we sailed 14 miles out then back. It was a great day. I put the boat on the face dock without incandescent.
Went out again today. We motored north up to Beaufort then headed over to The broad river at the tip of Paris Island. No problems getting back to the slip. I have a ghost on board?? What to do now. Start chasing what it could have been?
ltgoshen is offline
post #28 of 29 Old 05-28-2013
If all is now normal, it may well have been some air in the fuel which has now purged. But, if you can't make at least 3000 RPM you still need to find out why. Maybe the prop is wrong for the boat, maybe you are not getting full throttle, maybe the prop is just covered in barnacles.
Anyway, if it starts easy and runs without overheating or blowing excessive smoke, it seems as if the engine itself is OK. Always a relief, is that.
post #29 of 29 Old 05-29-2013 Thread Starter
First String
Yes,,, We did the 2 day sail in which I used the engine for 2 hours at 2000-2100 rpms. It did not seam to like it higher. I gave it all it had and could only reach 2500 rpms. I will change the fuel filter now that the weekend is over and have time to learn how to bleed the system out.
It was a great weekend 76 miles in all, 14 off shore.
Thanks again for your help
https://www.youtube.com/watch?v=cQ5xy4VI-44
ltgoshen is offline
YSM 12 dies after starting ggrizzard Diesel 2 06-29-2009 12:59 AM
Engine dies cdisney Atomic 4 9 11-20-2008 08:56 PM
Dies, wait, restarts kpdii Atomic 4 9 08-20-2008 01:37 PM
Engine dies, what would you do..... DrB Seamanship & Navigation 26 08-19-2007 09:40 PM
Engine Dies HELP!!! lauralee Gear & Maintenance 19 09-01-2003 07:43 AM
