Replacing Raw Water Pump Volvo Penta MD2010 - SailNet Community
post #1 of 1 Old 05-23-2013 Thread Starter
Hi
I have a Volvo Penta MD2010 that has been laid up over winter.
On the first start this year there was water leaking from the 'telltale' weep holes on the sea water impeller pump housing.
I found a spare water seal on board so replaced this by removing the old seal with pliers and then seating the new seal using a socket so it was flush with the back of the impeller housing. While doing this I noticed there was a fair amount of 'play' in the impeller shaft.
Replacing the seal made no difference an the leak remains so I ordered a replacement pump.
Does anyone know if changing the pump is an easy DIY job or not?
The new pump has a threaded end to the shaft that goes to the engine so I guess I will need to unscrew the old shaft - any tips for this?
There also does not seem to be a gasket to the engine block with the new pump so should this just be sealed with a liquid sealant?
Thanks!
FionaBowman is offline
Volvo Penta MD7A Injection Pump and Other Parts for sale SeaWolfe Introduce Yourself 4 07-04-2014 11:42 AM
volvo penta md2010 won't start tahoemark Diesel 17 08-03-2012 08:47 AM
Volvo Penta water pump shaft question. MD5A GMC Gear & Maintenance 1 04-16-2012 10:30 AM
Replacing our Volvo Penta Engine - Yanmar model? windtraveler Diesel 10 11-25-2010 02:59 PM
Volvo Penta MD7A Fuel Inj. Pump WRECKS Gear & Maintenance 2 09-01-2008 09:19 AM
