Repowering with an electric engine? - Page 12 - SailNet Community
 53Likes
post #111 of 158 Old 05-04-2014
mitiempo's Avatar
Re: Repowering with an electric engine?
Originally Posted by christian.hess View Post
...maybe in the next 5-10 years or so battery tech that is extremely expensive now will be really cheap then and getting more and better range will be plausible with maybe less initial expense.
LiFePO4 is a better battery, no doubt about that. Expense is the only real issue left to solve.
But the other half of the equation is charging. There is not a good solution to that coming that I can see.
Brian
mitiempo is offline
post #112 of 158 Old 05-04-2014
christian.hess's Avatar
not YET
jejeje
hope its soon
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #113 of 158 Old 05-05-2014
heres a decently priced eletric boat
Peterson 30' Sailboat - Electric Propulsion
post #114 of 158 Old 05-05-2014
this page has some nice battery kits, bit stil very expensive
Marine | EAS Electric Autosports Inc.
post #115 of 158 Old 05-05-2014
this is the page I got most of my info from and that I liked the most since the boat had the same palmer engine I removed from the boat and displacement is similar
Cabernet Electric conv
just thought id post these links up
post #116 of 158 Old 05-05-2014
Old enough to know better
but they go higher...and maybe they just want to get a bigger boat or something...it was just something I noticed from perusing the classifieds all the time
I think its quote the added value if you take into account its a certain market niche
the boats being offered where very well maintained, in marinas...and fitted for daysailing...
which is what most electric conversions have been applied to....
and last but not least its still a sailboat...
Well they ask more but that is very different than selling for more. There is a Bristol near me that has been on the market for at least 4 years. Was listed by a broker for a couple of years and is now on sailboatlistings. Looks like a nice professional install. But I can't imagine using it on the Hudson river as we have shifting currents and folks here motor a lot, especially upstate. Sail one way and motor the other way.
Broker thought it would be a perfect match for my preference for a composting head. Guess she thought I was an environmental hippy. Guess she is nor far off as I do enjoy sailing on the Woody Guthrie and she is electric powered. But she mostly day sails with shore power charging.
Sent from my ADR6425LVW using Tapatalk
christian.hess likes this.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #117 of 158 Old 05-06-2014
davidpm's Avatar
Originally Posted by Stumble View Post
Zee,
Then look at what Lagoon did. With a huge budget, massive technical support, and major commercial interest they spent years trying to get it right and then replaced (or offered to) all the electric drives they installed.
Do you have any links about Lagoon giving up on electric drive. I couldn't find any doing a quick google search.
davidpm is offline
post #118 of 158 Old 05-06-2014
Not really. They didn't really make a press anouncement, they just stopped offering them. My bet is they are waiting for the technology to advance to the point they feel it solves the problems they encountered, then will reintroduce it.
Greg
Stumble is offline
post #119 of 158 Old 05-07-2014
new and proud of it
Send a message via Yahoo to w1651
Originally Posted by mitiempo View Post
I have a question for anyone who has or is thinking about going electric.
Why? What were or are your reasons?
You give up range. You will have greater expense when replacing batteries every few years than the cost of maintenance of a diesel in good condition. Fuel costs cannot be the reason as fuel use by a sailboat is very small - probably a lot lower than the cost of driving to the boat in a vehicle over a season.
Because some of us actually sail. We actually read charts, and watch the ebb tides. We Sail! It sounds like from reading this thread most motor sail here. This may not be a good site for me after all.
Chris38 and christian.hess like this.
w1651 is offline
post #120 of 158 Old 05-07-2014
new and proud of it
My plan is this
1. install electric drive with proper gear ratio to prop it will regen at 3 to 6 knots(don't know how much yet)
2. install 8 batteries for a 48 volt system
3. Add 2 or 3 solar panels 24 volts each to charge batteries with a solar controller.
4. add a Missouri wind and solar wind generator but mounted upright with a vertical axis blade with a wind controller.
w1651 is offline
Tags
electric inboard , recharging , repowering , solar panels
which engine for repowering? prussell Diesel 8 02-01-2014 04:19 PM
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 17 10-13-2013 09:39 PM
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 06:27 AM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 02:46 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 12:23 PM
HTML code is Off
