Repowering with an electric engine? - Page 14 - SailNet Community
 53Likes
post #131 of 158 Old 05-07-2014
mitiempo's Avatar
Re: Repowering with an electric engine?
Why would a portable gasoline generator be better than a good diesel engine?
If you need a generator that shows the failing of electric drive systems currently. Diesel engines don't need a backup engine. And who wants to carry gasoline. Not to mention the additional fuel it really defeats the purpose of being green, doesn't it?
Brian
mitiempo is online now
post #132 of 158 Old 05-07-2014
christian.hess's Avatar
my sister lives in lund, bc
one day Ill be on a boat sailing those waters...
if I do Ill have a trusty old diesel to do so...
probably a big steel sailboat too...
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #133 of 158 Old 05-07-2014
yes
you are right but just be open minded
its like the outboard versus inboard crowd
an outboard you can take off the boat carry on your shoulder and get repaired anywhere in the world
a diesel while simple tech not always so
a generator is like an outboard while it defeats the completely green scenario its simply a GAS version of a diesel electric sub
a true hybrid
a prius in a boat
so while some might cry foul at this some wont and embrace it...
a portable genny also offers countless other pros for cruising...
like the abilty to use power tools on the fly, do a quick battery charge...power a compressor etc....
in regards to who wants to carry gas, well tons of people, panga fisherman, car drivers, the list goes on
if nobody carried gas then most 99 percent of cruisers wouldnt carry dinghies...right?
Chris38 likes this.
post #134 of 158 Old 05-07-2014
mitiempo's Avatar
I carry diesel and propane. My dinghy power is electric with a solar panel on top for charging. A 3rd fuel I don't want.
Lund is the jumping off point for Desolation Sound and you don't need a steel boat to cruise there.
Brian
post #135 of 158 Old 05-08-2014
Originally Posted by Alex W View Post
Why wasn't a <30lb Yamaha or Honda 2-2.5hp outboard the right motor for your racing boat? They are cheap, light (almost certainly lighter than any electric motor with batteries), and reliable. They are so light that you can store them below when sailing. This is the setup that I see a lot of J/24s use.
The electric setup was about 20lbs lighter than the next best option. The battery was the same one we would have carried to run the electronics anyway. So no weight gain from that.
And the motor was the lightest trolling motor that could get us to the 50% of hull speed as required by the racing rules. At the time the Honda 2.5 wasn't out, the lightest weight motor going was the Tohatsu 2.5 at 41lbs dry.
Instead we used a MinKota 30lb thrust trolling motor that weighed in at ~15lbs.
Again this is a very specialized setup I don't recommend for anyone outside the same situation. We had no range, no backup, no options. But for a fully crewed racing boat where there is no real intent to ever use the engine anyway it was fine.
christian.hess likes this.
Greg
Stumble is offline
post #136 of 158 Old 05-08-2014
cool pics
ps you dont need steel for anything really but why not? jajaja just feels applicable if you keep going north, since your that far anyways
anywhoo
post #137 of 158 Old 05-08-2014
no longer reading SailNet
Alex W's Avatar
The Honda 2hp has been around for 20ish years, but maybe that difference of 2hp vs 2.5hp was enough for you to get the 50% hull speed requirement. I have a greater than 20 year old Honda 2hp outboard for use on a dinghy.
Alex W is offline
post #138 of 158 Old 05-08-2014
I just bought an evinrude 3.3 its an early 90s version
thing wieghs 25 lbs...it be perfect for a racing boat or something like a j24 or similar
anywhoo
post #139 of 158 Old 05-08-2014
Alex,
The current Honda 2hp weighs in at 30lbs, but it wasn't on the market at the time. I highly doubt you have a 20 year old 2hp four stroke motor. I am pretty sure no one started making them until they were mandated by the Feds.
Greg
Stumble is offline
post #140 of 158 Old 05-09-2014
yeah they did those honda and suzuki 4 strokes with the ccs instead of actual horsepower on the cowling...
some of the first commercially made small 4 strokes...they just didnt catch on way back then
thats why you see a lot of sailors sticking to these engines dearly as they are highly desireable and RELIABLE
I also beleive they didnt have all the evap and emissions smog crap that the new 4 strokes all have and therefore lighter than an equivalent today
here is a bigger one
a 1983 7.5(this is the one I saw all the time on sailboats, a classic and standard!)
and what you are talking about, the absolute best back then(still)
Vintage 1980s Honda 4 Stroke 2HP Outboard Motor One Owner Well Maintained | eBay
new stuff has nothing on these bad boys1
Tags
electric inboard , recharging , repowering , solar panels
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 18 3 Weeks Ago 12:51 PM
which engine for repowering? prussell Diesel 8 02-01-2014 04:19 PM
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 06:27 AM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 02:46 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 12:23 PM
HTML code is Off
