Repowering with an electric engine? - Page 15 - SailNet Community
 53Likes
post #141 of 158 Old 05-09-2014
christian.hess's Avatar
Re: Repowering with an electric engine?
Originally Posted by Stumble View Post
Alex,
The current Honda 2hp weighs in at 30lbs, but it wasn't on the market at the time. I highly doubt you have a 20 year old 2hp four stroke motor. I am pretty sure no one started making them until they were mandated by the Feds.
actuall honda was at the forefront of "new tech" and greener technoologies even when it wasnt mandated by anyone or the feds...
a perfect example in cars was the hybrid way back in the late 80s and early 90s that looked like a very flat shoe with a big rear window...
the prius didnt come along until 15 or so years later...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #142 of 158 Old 05-09-2014
here is a vid of the little one
post #143 of 158 Old 05-09-2014
no longer reading SailNet
Alex W's Avatar
Alex,
I have the motor covered in this manual:
http://cdn.powerequipment.honda.com/...s/31ZV0610.pdf
Check the year on the cover: 1989. That is 25 years ago. I have a little newer one with different cowling graphics and silver paint instead of the older white. The cowling on mine is kind of comical, it says "Four" in huge letters, "stroke" under that, and the HP is written somewhere small. At a quick glance you'd think it was a 4hp motor.
About 15 years ago they switched it from having no transmission to the centrifugal clutch and the model number changed to BF2D. Sometime more recently it got bumped from 2hp to 2.3hp. It's a solid little motor and I see a lot of them used on dinghies when I'm out cruising. It has come in short and long shaft from the beginning.
A friend borrowed mine to use on her Columbia 22 when her outboard was acting up. It was a little underpowered, but got her where she needed to go.
christian.hess likes this.
Alex W is offline
post #144 of 158 Old 05-09-2014
thats even newer!
post #145 of 158 Old 05-09-2014
Wow. Sorry I missed it. I probably would have still gone electric, but it would have been nice to have reasonable options.
Greg
Stumble is online now
post #146 of 158 Old 05-24-2014
thought you guys might enjoy this for this that are still interested:
Electric Sailboat conversion | EAS Marine
look at the pic with the generator and custom made motor mount
pretty damn cool
he says at 4 knots he gets indefinite useage(portable genny fuel) with this setup
yeah it defeats the purpose I guess but this is no damn different than a ww2 sub with diesel electric for power...
post #147 of 158 Old 05-24-2014
sunfish?junior?
The trains that pull so many cars down the track Use a diesel to power an electric motor Some of the best fuel to weight that can be found for the money.
Kind Regards, Lou
Lou452 is offline
post #148 of 158 Old 05-25-2014
Lou,
Trains aren't diesel electric because they are inherently more fuel efficient, but because trains would otherwise have to use incredibly complicated transmissions to drive four powered axles and would need a lot of gears to keep the engine within its power band. The full torqu at 0 rpm is also incredibly useful. None of these things are particularly valuable to a boat however.
mitiempo likes this.
Greg
post #149 of 158 Old 05-25-2014
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
There has been a lot of valuable information on here. I looked into this a few years back, and quick and dirty, if you don't want to give up "range" you need a generator roughly the same size, HP wise, as the engine you are replacing. The entire system is larger, heavier, more expensive and more complicated than the engine you are replacing. I think you also need to look at the pollution free aspect of electric. If you recharge with shore power, you are not pollution free, as in the US a lot of power generation is coal fired, and while scrubbed, it is not clean. I know that lead acid batteries have a good recycle rate over their life cycle, bu I am not sure about Lithium batteries, in the various combinations. I do not know what the "pollution" footprint of manufacturing or discarding a solar panel is, but I suspect there is one. In short the least polluting answer is likely a diesel with a catalytic converter and enough green plants on board to reconvert the CO2 back to O2. No I do not have statistics, just a gut feeling that there is no free lunch in pollution control either. My town still has a "recycle" trash pickup, but the "recycling" is added to the regular trash stream, as it is cheaper. So we actually have twice as many pickups and therefore trash trucks running, so the net effect is that "recycling" adds more pollution than not "recycling". Yes this is a very cynical policy, but it keeps taxes low, and the mayor re elected and most folks in town feel good about their "re cycling".
This has become longer than I'd like, but for me the real "green" solution is fighting for pollution controls on all IC engines, and creating green space. I am well aware that IC engines of various sizes and uses are NOT the largest source of pollution compared to factories and utilities, but that is a fight for another day.
Since it is memorial day, go visit a WWII submarine museum and thank those pig boat sailors for their service. You'll also realize that the engine and battery spaces were much larger than the crew quarters. Time for a new thread on small nuclear power plants for sailboats?
Lou
lillia28 is offline
post #150 of 158 Old 05-25-2014
jajaja good stuff
Tags
electric inboard , recharging , repowering , solar panels
which engine for repowering? prussell Diesel 8 02-01-2014 05:19 PM
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 17 10-13-2013 10:39 PM
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 07:27 AM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 03:46 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 01:23 PM
HTML code is Off
