Repowering with an electric engine? - Page 7 - SailNet Community
 53Likes
post #61 of 158 Old 03-02-2014
Maine Sail's Avatar
Re: Repowering with an electric engine?
When we discuss battery weight we need to be cognizant of the fact that you will still need a 12V house bank so the 48V propulsion bank may weigh 520 pounds but then the house bank may be another 130 or so pounds making for approx 650 pounds of batteries on a 28 foot boat. If you are real energy conscious you could get away with a single 65 pound house bank.
With diesels we also have fuel capacity weight, which is not very light weight. A 20 gallon tank when full would weigh about 140 pounds +/-.. So 175 pound engine + 140 fuel = 315 pounds.
This makes an 8 cell GC2 bank about 200 pounds heavier not including the weight of the electric motor and gear which can be 100 pounds +/- with wire mounts, motor etc...... So on the O'day 28 it is conceivable the the electric motor conversion ads about 300 +/- pounds over diesel to the boat. If properly placed not a huge deal..
davidpm and zeehag like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #62 of 158 Old 03-02-2014
asdf38's Avatar
Nice thread.
It's a bummer because electric motor and controller technology is well developed. The motor controllers have taken advantage of continuous development in the semiconductor industry to make use of the latest Mosfets/IGBT's and microcontrollers.
The motor and controller are high efficiency and have basically zero moving parts besides the shaft and bearings which is ideal for a harsh environment.
But...batteries stink. The fact that lead acid still enters the discussion despite being invented in 1859 is indicative of the problem. Better battery technology exists (lithium) but has a host of caveats (including cost).
The bummer is that electric would be wonderful for a sailboat for a number of reasons. Besides reliability potential (no moving parts), they come on instantly. Great for an "oh crap" blown tack.
And they're quiet. Every sailor appreciates that. I love my yanmar but the best moment sailing is the moment I shut it off.
There is absolutely massive incentive from a huge number of industries for better battery technology, hopefully it comes through eventually, but I don't exactly expect it. I think we're going to have to stick to Diesel for a while to come.
davidpm likes this.
asdf38 is offline
post #63 of 158 Old 03-02-2014
This company has been doing some conversions near you in S.Cal., there might be some info on their website that would be helpful. I tried driving an electric Ranger pick-up back in the day, I liked it but range and battery weight were problems, and running the air conditioning or heater was sure to leave you walking.
Electric Options
"Just call me TB"
capttb is online now
post #64 of 158 Old 03-02-2014
mitiempo's Avatar
Even with better battery technology, such as lithium, you still have to put the amps back in the bank. That's the biggest roadblock.
zeehag likes this.
Brian
mitiempo is offline
post #65 of 158 Old 03-04-2014
asdf38's Avatar
I mean you can't "recharge" your fuel tank. You have to pull up to a specialized station to fill up - something that's already impossible in remote areas or offshore.
So if the energy storage issue is addressed, and you can carry around the equivalent electrical energy of your gas tank (or a sizeable fraction of it) then electric becomes a fantastic solution for most people.
It's still not perfect because you can't add extra "tanks" as easily (you can add batteries but the downside is that a dead battery takes the same size and weight as a charged one).
Personally I had my best season last year and went through less than half a tank (15 gallons) the whole time. If I could store the equivalent of 5 gallons, I'd be all set. Worst case I'd have to pull up to a dock once a season for an overnight recharge. Not a big hassle at all.
christian.hess likes this.
asdf38 is offline
post #66 of 158 Old 05-01-2014
new and proud of it
Send a message via Yahoo to w1651
I'm in the process of installing a electric drive. I have to get past how to mount it and the right ratio for my boat. I fear it will be a trial and error process there but mounting will be relatively easy. I also need to figure out how to install some type of thrust bearing to keep the prop shaft in one place. not moving back and forth through the stuffing box.
w1651 is offline
post #67 of 158 Old 05-01-2014
christian.hess's Avatar
what system? what boat? they sell thrust bearings in many places...
the place I like is electric motorsport.com they also sell a number of pulleys, belts, chains, sprockets etc to work out the right ratio
I still dream of this jajaja
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #68 of 158 Old 05-01-2014
snake charmer, cat herder
zeehag's Avatar
solar panels are a must on a boat with electric propulsion, as is wind power. everything possible to restore charge must be used including a back up genny. there is no diesel electric option such as forklifts and some others use... this should be developed as a diesel electric option would recharge batteries as you run, instead of having to have separate solar and wind charging constantly.
formosa 41, cruising tropics
zeehag is offline
post #69 of 158 Old 05-01-2014
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by zeehag View Post
... there is no diesel electric option such as forklifts and some others use... this should be developed as a diesel electric option would recharge batteries as you run, instead of having to have separate solar and wind charging constantly.
Beta brought out an electric diesel hybrid just after we did our repower two years ago.
Beta Marine | Marine Diesel Propulsion Engines and Generating Sets | Greenline | Inland Waterways Hybrid Propulsion Engine
When we considered straight electric, the manufacturers said that solar and wind were not enough to recharge the engine to get more than another hour or so out of it. That's what stopped our conversion. When we retire it may be an option again.
Chris38 and christian.hess like this.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #70 of 158 Old 05-01-2014
yup
there are quote a few diesel electric options out there right now but very very expensive
my last plan was to have wind and solar setup in 48volts...to ever so slowly replenish the small 4 battery bank
again my plan for electric was to use only for in out marina and anchor, 1-2 hour run time max
use a stepdown converter from the 48 volts to 12volts for the house "batteries" and useage
in any case...just a dream at this point
my issue was I wanted a self sufficient system and not invest in the very expensive chargers since marina charging was out of the question.
anyways hopefully in the next 5 years something else pops up
Tags
electric inboard , recharging , repowering , solar panels
which engine for repowering? prussell Diesel 8 02-01-2014 04:19 PM
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 17 10-13-2013 09:39 PM
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 06:27 AM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 02:46 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 12:23 PM
HTML code is Off
