Repowering with an electric engine? - SailNet Community
 53Likes
post #1 of 158 Old 02-01-2014 Thread Starter
OUPV 25 Ton
CaptainRahnn's Avatar
My engine is getting old and was wondering if anyone has installed an inboard electric engine or considered doing so. I have a Cal 34 mkii and was interested in getting opinions on recharge times with solar and wind?
CaptainRahnn is offline
post #2 of 158 Old 02-01-2014
The most female moderator
Donna_F's Avatar
Dock
Re: Repowering with an electric engine?
We considered it. Hard. The deciding factor was that it couldn't get recharged enough to give us the range we need.
(moving this to the Electric forum)
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #3 of 158 Old 02-01-2014 Thread Starter
OUPV 25 Ton
Question Re: Repowering with an electric engine?
Not actually sure how to move it to the electric forum
post #4 of 158 Old 02-01-2014
Donna_F's Avatar
Dock
It's there already. Magic happens.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #5 of 158 Old 02-01-2014
Are electric motors ready to replace diesels? - Ocean Navigator - September 2011
captain jack likes this.
aa3jy is offline
The Following User Says Thank You to aa3jy For This Useful Post:
captain jack (02-12-2014)
post #6 of 158 Old 02-04-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I do not know about an inboard.. but I know the replacement outboard for my Sea Sprite will be a torqeedo
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 158 Old 02-04-2014
Old enough to know better
Yea, the big issue is capacity. A gallon of diesel is equal to about a thousand pounds of batteries. So you get a few hours of range at best unless you put in a LOT of batteries. I would love it if it was practical. I sail on a boat with a dozen huge deep cycles and electric motor, it is nice to have instant on power, though surprisingly noisy. They normally sail on and off the dock anyway. (32 foot wooden boat) But it is only sailed very locally so you are not out of range of the batteries. It was done for ecological reasons, not cost, and they are wiling to live with the limitations.
If all you want to do is get on and off a mooring, it can work. But if you are one to use the motor to maintain any schedule when the wind drops then it is likely not for you. Not bad if you are wiling to sit still in a calm waiting for the wind to come back, or in an area with very regular winds.
miatapaul is offline
post #8 of 158 Old 02-04-2014 Thread Starter
OUPV 25 Ton
How long would it take to recharge with 1000 watts of solar panels or wind turbine or both. They are rechargeable just wondering what kind of time frame are we talking about?
post #9 of 158 Old 02-04-2014
Maine Sail's Avatar
How big is the bank?
What voltage is the bank?
What type of chemistry?
What depth of discharge for each cycle?
______
-Maine Sail / CS-36T
Maine Sail is offline
post #10 of 158 Old 02-04-2014
mitiempo's Avatar
According to CaptainRahnn's profile his boat is a 34' Cal. Where does one install 1000 watts of solar on a 34' boat I wonder?
Brian
mitiempo is offline
Tags
electric inboard , recharging , repowering , solar panels
which engine for repowering? prussell Diesel 8 02-01-2014 04:19 PM
Replacing Engine Driven Water pump with electric seanreid71 General Discussion (sailing related) 17 10-13-2013 09:39 PM
Replacing IC engine with electric motor WilliamsRDan Electrical Systems 13 10-11-2012 06:27 AM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 02:46 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 12:23 PM
HTML code is Off
