High Battery Reading 15.7 - Page 2 - SailNet Community
 2Likes
post #11 of 14 Old 06-13-2014
christian.hess's Avatar
Re: High Battery Reading 15.7
btw if indeed you have 15.7 volts at the battery with nothing connected...many things like small bulbs and the like or fuses might pop...so are you absolutely positive that the voltage is 15.7 with NOTHING connected to the battery, not even the battery switch, negatives etc...?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 14 Old 06-13-2014 Thread Starter
Thanks for all the info.
It is a 12 volt, flooded deep cycle battery. From the posts, I see the problem.
I will replace the battery. So, for a Group 24, flooded, deep cycle battery using a 30 watt panel what would be the specifications for a pwm charge controller? Best brand of controller to buy?
Also, I am just wondering why this battery is reading 15.7 and did so all winter with no charging at all. I checked it with two voltmeters.
petertribo is offline
post #13 of 14 Old 06-13-2014
a 10amp pmw will do you good...and allow for adding another panel at a later time...
post #14 of 14 Old 06-15-2014
mitiempo's Avatar
Best choice is a Genasun MPPT controller - the GV-4 if the 30 watt panel is all you will have or the GV10 if you plan to add another panel. They will give you the best charging from the panel at the proper voltage.
Brian
mitiempo is offline
How to cruise reading deniseO30 General Discussion (sailing related) 24 07-30-2012 11:20 AM
High times for women on high seas NewsReader Mass Bay Sailors 0 08-03-2007 08:15 AM
Prada goes from high fashion to high seas - El Paso Times NewsReader News Feeds 0 05-09-2007 02:15 AM
High Tech on the High Seas Epiphany General Discussion (sailing related) 3 01-25-2004 02:32 PM
Chart Reading wannasail Learning to Sail 3 07-19-2002 07:34 AM
HTML code is Off
