High Battery Reading 15.7 - SailNet Community
 2Likes
post #1 of 14 Old 06-11-2014 Thread Starter
Hello, once again sailing in Nova Scotia after one long Winter.
I have checked my marine battery with two different voltmeters and I get a high reading of 15.7.
I checked this battery throughout the winter and got the same reading. I understand this may indicate a worn out battery. Is that correct?
Also, with a 30 watt solar charger connected to the battery in full sunlight what reading should I be getting on the battery?
Any recommendations for best marine battery?
Thanks.
Peter, Elan 7.7 trimaran
petertribo is offline
post #2 of 14 Old 06-11-2014
Zanshin's Avatar
Re: High Battery Reading 15.7
The resting voltage of the battery depends on what type it is, each battery chemistry has different optimal values. Along the same lines, a 30W unregulated solar cell could be putting out 18V and could overcharge the battery so the voltage reading at charge could be any value. It depends upon which charger and what charge method it uses.
christian.hess likes this.
Zanshin is offline
post #3 of 14 Old 06-11-2014
christian.hess's Avatar
bingo...I bet that panel is unregulated...
are you testing the battery voltage isolated from the panel and all other sources?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #4 of 14 Old 06-11-2014
Maine Sail's Avatar
This is NOT GOOD...
By now your batteries are pretty much toast if the meters are to be believed..
Thanks.
You can't simply direct connect a 30W panel to a battery without a charge controller. Sounds like you need a controller and a new battery....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 14 Old 06-12-2014 Thread Starter
Thanks for the replies.
I checked the battery without the panel connected. I had checked the battery periodically throughout the winter and it read around 15.
Another piece of information is that connected to the panel which is in full sunlight the reading only goes up to about 16.5. I remember is as being much higher.
The battery is about 4 years old. Years ago, I had read that a 30 watt panel could be directly connected without a controller. So, it was connected directly on a previous boat and now this one. The batteries seems to have lasted about 4-5 years.
Also, there is low drain on the battery just an autopilot and handheld GPS.
post #6 of 14 Old 06-12-2014
Zanshin's Avatar
Can you tell us the make and model of the battery, then we can put the voltages you see into perspective.
Here's a YouTube video showing how batteries can be damaged with a small unregulated solar panel: https://www.youtube.com/watch?v=z5RtZe9AW2E
Zanshin is offline
post #7 of 14 Old 06-12-2014
Im surprised they lasted that long...
I killed a flooded deep cycle in one season by connecting a smaller 10-15watter but it went up to 18-19volts unregulated...
it was the first time I was away from a boat so long so figured it was fine...but I learned the hard way...battery was completely shot when I got back 6 months later
you must explain what battery type you have some have high voltages as standard around 14.5 volts...forget which ones..
post #8 of 14 Old 06-13-2014 Thread Starter
It is a Group 24, deep cycle marine battery.
It is not a fixed solar panel. My normal practice is to set the panel up when finished sailing.
I disconnect and store it when I sail. Depending on weather etc. I may get a few hours charge. It is never left connected for more than a few days.
post #9 of 14 Old 06-13-2014
Zanshin's Avatar
petertribo - Group 24 just refers to the size, and deep cycle means it has thicker plates, but neither tells us what the voltages should be. Do you have a make and model? Is it a sealed battery or can you check liquid levels in it?
Zanshin is offline
post #10 of 14 Old 06-13-2014
its more than likely a floooded acid battery where typical charging voltages are around 13.5 and the battery when alone should be in the normal 12.5-13v range if in good condition
btw op just cause you disconnect the panel doesnt mean you arent doing harm when charging...
its still pumping out over 16 volts...I bet at midday sun with clear skies you will see 18 volts
thats still an UNREGULATED panel so either get a cheap pwm charge controller or get a better panel and use mppt controller to get the suns full advantage
cheers
How to cruise reading deniseO30 General Discussion (sailing related) 24 07-30-2012 11:20 AM
High times for women on high seas NewsReader Mass Bay Sailors 0 08-03-2007 08:15 AM
Prada goes from high fashion to high seas - El Paso Times NewsReader News Feeds 0 05-09-2007 02:15 AM
High Tech on the High Seas Epiphany General Discussion (sailing related) 3 01-25-2004 02:32 PM
Chart Reading wannasail Learning to Sail 3 07-19-2002 07:34 AM
HTML code is Off
