Adding an auxiliary electric motor might be fun... - Page 2 - SailNet Community
 4Likes
post #11 of 23 Old 07-09-2014
Re: Adding an auxiliary electric motor might be fun...
Don't know, but used as intended by MedSailor..a 160 lb. thrust with the right prop
could deliver the desired 2 h.p. ...depending on who's formula/math you use.
Seems motorsailing at rather low rpms (thrust), provides a synergy beyond
the math.
Maybe worth a look at website if nothing else.
christian.hess likes this.
HUGOSALT is offline
post #12 of 23 Old 07-09-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
HugoSalt
While I doubt a trolling motor would do me much good, I really DO appreciate the suggestion. I just procured a large sized Torqueedo outboard, and your idea gave me the idea that I should try stern mounting the Torqueedo and see what it does. It's quite a bit more thrust than a trolling motor, and would be easy to implement. Even if it doesn't do what I desire, I could use the thrust specs to help guesstimate how big of an internal electric motor setup I will need.
MedSailor
MedSailor is offline
post #13 of 23 Old 07-09-2014
Chains and sprockets are inherently noisy. This is why so many cars went to "rubber" timing belts instead of metal timing chains.
And who needs a clutch? When you are not driving the electric motor, isn't it a DC generator that can be left attached, charging your batteries, heating your water, doing other useful work?
hellosailor is offline
post #14 of 23 Old 07-09-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
An interesting thought about chain noise. I can't imagine it would be that bad... I once went to an electric boat talk and the guy giving the presentation said his company used supercharger belts. Said they were immensely strong. I could use those, I suppose but the parts seem less easily available.
I could leave it attached, but then I'd need to make sure it was adequately cooled, could handle the max RPM of the motor for long periods and would have to regulate the charging current. I'm sure my 90HP engine has a few extra HP to give up, so the draw on the engine shouldn't be a problem. Not impossible to set up this way at all, but simple is part of what I'm after.
MedSailor
post #15 of 23 Old 07-09-2014
christian.hess's Avatar
simple is slap on a dc motor on the shaft with sprockets to use as an alternator....since its dc volts go back in when you want to use it as a silent dc motor...all electric.
chain and sprockets make no more noise than the mosy silent diesel engine...so that nonsense doesnt pan out....
lube...clean and do like you would a bike chain
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #16 of 23 Old 07-09-2014
Problem with chain drive is it's on all the time unless you've got a clutch on the shaft itself. Possible but I've never seen a suitable critter. One could make something up using the syncro slider like a dog clutch from a truck trannie but that gets more complicated.The belt drive doesn't touch the shaft when slack and idler operated by a lever, wedge or remotely turned screw .When the shaft is electrically engaged the transmission is turning (oil cooling etc)so this is not a stand alone gizmo for long. Also the side pull of the belts on the shaft is considerable and can bend a toy . I put on a Maxi and never looked back.
Capt Len is online now
post #17 of 23 Old 07-09-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
Why is chain on all the time? The way I'm picturing this it's no different than belts but eliminates the side loading issue. What about watermaker and engine refrigerator clutches? Couldn't I use whatever they use but with chain?
Btw what do you mean by "I put on a maxi". I can only think of one meaning for that and I'm quite sure it isn't what you meant. [emoji1]
post #18 of 23 Old 07-10-2014
Instead of chain use a cog belt sometimes called timing belts, as to clutches, just let it spin, unless you have a huge gear reduction there will be little drag,
Best would be if you could find a double shaft motor that runs the same speed, rpm, as the shaft, and you have the clearance from gearbox to seal to fit it. think WarP motor.
I'd like to do this mostly to power on/off dock, mooring, for 2-5 minutes without starting the diesel, and could also use it as a big alternator
P35juniper is offline
post #19 of 23 Old 07-10-2014
Len ment Max-Prop
post #20 of 23 Old 07-10-2014
D3, Depends on your needs but that makes me feel better
Adding a auxiliary outboard. Zuma Gear & Maintenance 25 02-04-2014 11:00 AM
is anyone using an electric motor to get out of the marina ABH3 Boyer General Discussion (sailing related) 25 03-27-2013 09:31 AM
electric motor mszczepa General Discussion (sailing related) 18 07-06-2010 06:24 PM
Adding electric compressor to engine-run fridge Bene505 Gear & Maintenance 19 03-08-2009 12:23 PM
Does anyone use a Electric Trolling Motor poopdeckpappy Gear & Maintenance 23 10-19-2007 09:08 PM
HTML code is Off
