Electrical Problem - SailNet Community
post #1 of 7 Old 05-31-2013 Thread Starter
Voltage Drop Problem ???
My Columbia 8.3 is powered by an atomic 4 engine. Every time I start the engine my Garmin 178C shuts off. No problem energizing it again while engine is running or when engine is off. I'm thinking the starter motor draws enough current to drop the voltage enough to cause the Garmin to shut off. I'm thinking of installing a single battery dedicated to the Garmin alone but wondering if there might be an alternative to this. The deep cell battery bank is new. Any thoughts
weephee is offline
post #2 of 7 Old 05-31-2013
Freedom 39
FarCry's Avatar
Re: Electrical Problem
You are correct in that your voltage is dropping too low causing the Garmin to shut down. I wonder how low your voltage is dropping. Do you have a way to check? What do you have for a battery bank(s)?
FarCry is offline
post #3 of 7 Old 05-31-2013
Fresh water refugee
katsailor's Avatar
Start relay shutting off unnecessary loads while cranking? Is Garmin wired directly to the battery positive bus?
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #4 of 7 Old 05-31-2013
MikeOReilly's Avatar
Hi weephee, I see you're in Ottawa. Do you sail the Ottawa River? I used to live there, but got into sailing after I left.
Deep cycle batteries are not very good starter batteries. They're designed to sustain deep discharge, not to deliver big amps quickly, as is needed for starting an engine. They can do it, but a big drop in voltage during the start is not a surprising outcome.
I'd suggest buying a dedicated starter battery, and keep the deep cycle as the house battery.
Why go fast, when you can go slow.
MikeOReilly is online now
post #5 of 7 Old 05-31-2013
tommays's Avatar
The GPS should REALLY be on a house bank as even and A4 with perfect stuff is going to drop the voltage below the GPS units low voltage level
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 7 Old 05-31-2013 Thread Starter
I have two new Costco (Kirkland) deep cell batteries. Also have the battery switch for #1 or #2 or both. Not sure what the voltage drop is but it wouldn't be hard to check with a volt meter when I'm cranking. The Garmin is hooked up to the DC panel buss but not to a breaker. It has an inline fuse. Mike, I keep my boat at Kingston on Lake Ontario.
weephee is offline
post #7 of 7 Old 06-02-2013
Stu Jackson's Avatar
It all depends on how it's wired.
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Windlass Electrical Problem neilmcd Electrical Systems 0 01-24-2012 07:09 PM
electrical 125 volt problem billthomas Introduce Yourself 1 03-30-2011 02:04 AM
electrical problem captkirb Gear & Maintenance 6 10-14-2010 12:36 PM
Electrical draw problem sailnaway Gear & Maintenance 1 12-13-2004 01:24 PM
Funny Electrical problem Bruceo1 Gear & Maintenance 2 12-15-2003 06:01 AM
