Best per $ solar panel suppliers? - Page 2 - SailNet Community
post #11 of 16 Old 06-07-2013
Superior Sailor
Squidd's Avatar
Re: Best per $ solar panel suppliers?
Any thoughts on Bosch panels...?
Sounded like a good german electrical name brand...had it shipped in from UK...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #12 of 16 Old 06-07-2013
snake charmer, cat herder
zeehag's Avatar
i picked up a marine grade solar panel in mazatlan from a cruiser at a swap meet--this panel had much problem with electrical connections. i could not make it work at all, and had to rewire entirely to learn that.
i bought 3 solar panels bp brand-at the same marine swap meet for a total of 50 usd complete with mppt controller. they rock. btw--not "marine grade"...
i have one kyocera--is a replacement from a city that changes them out yearly due to hail--was free tome...lol..is resting--huge 130 wtt panel--i have plenty of incoming electricity from the 3 bp plus one kyocera i am using.....i also have a unisolar semi rigid panel rate d 3.8 amps i would love to test here in tropics--gave me 2 amps in sd.....these are not marine grade, have been around longer than the one i bought that was spozedly marine grade--and my connections are not rotten as were the marine grade connexions..lol..
i see no reason for marine grade in something that lives outside normally. check connections regularly--is part of my semi annual checks when i anchor after a passage.
btw--i have been using uni solar flexible housing panels on my ericson for 9 years without problem, and no deterioration....i love that word in conjunction with panels, as i get mine cheap when you guys say it is deteriorated and i plug it in with my bad wiring an dfind it awesomely perfect putting out that which the rating states....
.thanks to you folks for dispo-ing such good stuff....
formosa 41, cruising tropics
zeehag is offline
post #13 of 16 Old 06-07-2013
Skipper Jer's Avatar
Been watching the solar market for a few years.
Here are a few links to places I've found.
Solar Panels, PV Systems and Inverters Distributor
Solar Cell, Solar Panel, Renewable Energy, Wind Energy, Charge Controller, Solar Trackers
What I've found intriguing is the flexible panel. 144 watts, 18 feet long (boo), and only
17 pounds (7.7 kgs for our Canadian readers) at around $141.00.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #14 of 16 Old 06-10-2013
I used Solar Cell, Solar Panel, Renewable Energy, Wind Energy, Charge Controller, Solar Trackers, the Sharps I purchased were actually manufactured in Tennesee. Freight ship to commercial addresses will save you some $. I can also second Maine Sail's recommendation for Arizona Wind & Sun, I wasn't familiar with that outfit when I placed my initial order. Good luck!
wouldrathersail is offline
post #15 of 16 Old 06-10-2013
no longer reading SailNet
Alex W's Avatar
As far as I could find there really aren't any name brand 20 to 50 watt panels left. Sharp, Kyocera, and the others have left that market space.
Both of my boats have had cheap panels and they've been working okay and as advertised. We'll see if that changes with time.
Alex W is offline
post #16 of 16 Old 06-19-2013
redline's Avatar
I bought my Kyocera panels and BlueSky MPPT controller and remote from altestore.com - no affiliation, just a very satisfied customer.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
solar panel QuickMick Gear & Maintenance 15 01-18-2016 04:36 PM
solar panel MarkusM Gear & Maintenance 7 02-17-2013 12:41 AM
solar panel alan_21_us Gear & Maintenance 12 07-31-2008 10:18 PM
B32 & Solar Panel Dcneuro Bristol 2 07-26-2007 10:56 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 11:02 AM
