Autohelm 3000 Remote Pin Connections - SailNet Community
post #1 of 5 Old 06-09-2013 Thread Starter
Hello all
I need to know the wire color asignments for the REMOTE port on an Autohelm 3000 (Z073). The wires I ned to connect to the REMOTE port are blue, green, red and ground (shield) but I need to know which pin each wire connects to. Inside the Autohelm the pins are numbered 1-4 OR they can be referenced from the "notch". It a,so appears the red wire might not even be used.
The Autohelm is model AH3000 and it uses NEMA 0183. Specifically I want to wire in a Radio Navigation Interface (Z075) which plugs into the REMOTE port. The plug is missing from the Z075 and so I need to know which wire from the Z075 goes to which pin on the AH3000 REMOTE port.
Can anyone help me? Can you suggest who might help me?
THANKS
magic32 is offline
post #2 of 5 Old 06-15-2013
PhilipStevens's Avatar
Send a message via Skype™ to PhilipStevens
Re: Autohelm 3000 Remote Pin Connections
There are quite a few AH3000 questions on this Google link - Google link
or here Google
Is it the round plug connector or the "oval/square" type connector? I have the connection diagram for the round plug.
This is the connection for the AH1000 andAH2000, looking from the back, top connection is Black and Screen - -ve, left connection is Yellow - Seatalk, and right is Red - +ve.
It is also the same connection layout for the AH3000, as I changed my AH3000 control head for an ST3000 control head, and is the same connections for the oval/square connector.
Any help??
Is this drawing of use?
regards,
Philip.
PhilipStevens is offline
post #3 of 5 Old 06-17-2013
There is a AH3000 head here ebay.co.uk
regards,
Philip.
post #4 of 5 Old 06-17-2013 Thread Starter
Thanks again Philip.
The picture you posted is my exact unit. The REMOTE port I need to access is second from the right. I took my unit apart to try and see the wire colours but inside is a simple grey ribbon cable, no indication of colours. Too bad!
I still think my only chance into find someone with a remote unit which will fit this Autohelm unit, who will undo the cable end and relay the wire colours with reference to the notch. It is simple and will not damage the cable in any way, but will reveal the pin assignments. Perhaps I will find a remote online and buy it?
Thanks again
magic32 is offline
post #5 of 5 Old 06-22-2013
Looking at the front of the plug with the notch at 12 oclock, going clockwise;
Green
Red
shield
Blue
This is for the remote. I believe that the Nav interface is different.
CaptainDan99 is offline
Got an old Autohelm 3000 remote? Don Foley Gear & Maintenance 15 01-17-2013 02:42 PM
Autohelm 3000 jbrener Gear & Maintenance 0 06-18-2009 07:48 AM
Autohelm 3000 TQA Gear & Maintenance 0 06-09-2009 12:21 PM
Autohelm 3000 remote Harlee Gear & Maintenance 5 03-19-2008 03:12 PM
Autohelm 3000 JimB34 Bristol 0 06-22-2007 10:37 AM
