Adding GFCI Outlet: Looking for Surface mounted back box - SailNet Community
post #1 of 2 Old 06-09-2013 Thread Starter
I am installing a simple shorepower system in a boat that preiousvly did not have one.
I would like to find a single gang surface mounted (non-metallic)outlet box to mount a GFCI outlet on top of the interior paneling versus cuttin a large hole in the paneling. Does anyone know of a good source for such boxes and would the box (or backbox) have to be UL rated.
I would actually like to find something made out o teak if possible.
I have found a some Leviton suruface mouted boxes but they do not appear to be UL rated.
Leviton 42777-1WA BACKBOX S/G 1.89" WHT - OneStopBuy.com
Thanks,
NS22Simple
ns22simple is offline
post #2 of 2 Old 06-10-2013
Freedom 39
FarCry's Avatar
Re: Adding GFCI Outlet: Looking for Surface mounted back box
I wouldn't get too hung up on UL ratings but would look for NEMA ratings instead.
The requirements of an electrical box are to contain potential arcing and heat to prevent the spread of a fire. In your case, mounting a device (GFCI) receptacle is also a requirement. By it's very nature, flammable materials, like wood, do not make sense for containing potential electrical faults or fires. There are some polymers that do meet NEMA standards that are non-metallic. Carlon, Panduit, and Hubbell some brands that come to mind. Any electrical retailer near you should have something that will work. You can also look at Grainger. I believe they have an online catalog.
You could always put some teak veneer over the outside of whatever box you choose.
FarCry is offline
"Marine" GFCI Outlet? SEMIJim Gear & Maintenance 82 12-24-2015 09:38 AM
Single pole surface mounted 12v switches? 4arch Gear & Maintenance 4 04-01-2013 10:29 AM
adding a cockpit AC outlet rmeador Gear & Maintenance 5 12-13-2010 08:20 PM
Surface-mounted ports GoodOldBoat Good Old Boat 15 01-14-2010 07:13 AM
Adding 12v outlet properly josrulz Gear & Maintenance 15 06-11-2009 10:31 AM
