Yanmar 2gmf tachometer pickup - SailNet Community
 2Likes
  • 1 Post By SlowButSteady
  • 1 Post By fryewe
post #1 of 5 Old 06-10-2013 Thread Starter
boz86's Avatar
Backstory: Engine ran with tachometer functional when I put it away for winter. Had new engine mounts installed by a boatyard nearby recently, engine wasn't running when it went over so I can't say whether the tach worked right before it went in the shop.
Tachometer not working now. My Yanmar manual is awol. I can't verify where the tachometer pickup should be, and although if this engine has a flywheel pickup it should be obvious, I thought I'd ask if anyone knows.
First question, where is the pickup on this engine -- everything I've read says it's not an alternator pickup.
Also, anyway to test the pickup with a voltmeter (etc)?
The shop says they'll send someone over, but if it's just a wire I should be able to reconnect, and if it's not I'm responsible anyway so I'd rather do it myself. Our slip is a couple of miles from the boatyard which is why I dont' want to waste their time.
"The Stone Age did not come to an end because we ran out of stone." Sheikh Yamani
boz86 is offline
post #2 of 5 Old 06-10-2013
Senior Slacker
SlowButSteady's Avatar
Re: Yanmar 2gmf tachometer pickup
The pick-up is on the top of the clutch housing, just to the right (looking from the front; or port-side, with the engine in the "normal" configuration) of the centerline.
Edit:
Do a search for "Yanmar GM/HM Workshop Manual". There are pdf copies online.
Faster likes this.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 5 Old 06-11-2013 Thread Starter
boz86's Avatar
Thanks much. Now I can't find my paper copy and my internet connection is down.
boz86 is offline
post #4 of 5 Old 06-11-2013
fryewe's Avatar
Uhhhh...how did you post this without an internet connection? I want to know! I want to be able to post to the internet when my connection is down!
(I usually use my cell phone edge connection.)
rikhall likes this.
fryewe is offline
post #5 of 5 Old 06-11-2013 Thread Starter
boz86's Avatar
Posted with a cell phone, but I'd much rather look at pdf on a larger screen.
Wait, I mean it was magic!
And my internet is back up so I'm off on a search.
boz86 is offline
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 14 04-10-2013 09:46 PM
Yanmar 2GMF problems Kiltmadoc Diesel 6 08-22-2012 03:46 AM
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-20-2010 12:03 AM
Looking for a used Yanmar 2GMF or? captsam54 Diesel 0 08-09-2009 04:43 PM
zincs for Yanmar 2GMF Julie303 Gear & Maintenance 13 11-16-2007 03:00 PM
