Solar vs. Wind Turbine. - Page 2 - SailNet Community
 3Likes
post #11 of 13 Old 07-02-2013
Re: Solar vs. Wind Turbine.
Windgen...D400, VERY quiet and good output. Otherwise go solar
xort is offline
post #12 of 13 Old 07-03-2013
i have both,get the solar first,but in the winter its nice to have wind also.solar is plug and play,set it and forget it almost...when there is a near gale outside i have measured up to 24 amps in a good gust of wind.on a normal day ,bank is full and wind is shut down and solar is taking only 1 or 2 amps at rest..
norsearayder is offline
post #13 of 13 Old 07-03-2013
Glad I found Sailnet
Bene505's Avatar
Originally Posted by freedoman View Post
I've had a wind generator on my Gulfstar 37' sloop since 1991 and wouldn't consider doing without it. I have 3 group 31 Defender batteries (130 a/h each and they stay topped off most of the time. The unit is a Four Winds that is so quiet people come by and find it hard to believe how quiet it is. I bought it with a control unit that measures output and state of charge of the battery. It also has a bump start to get it going in light air, a reverse switch which reverses the field to stop the unit so I can put a lanyard on it when I leave. Similarly it has a spring load governor that deflects when the wind speed gets too high and slows the unit down; and finally it has a 3 stage regulator that keeps the batteries from overcharging. If we're on the boat for days with slight wind I simply leave it running when I go home and the batteries are topped off when I get back. I'm not at all against solar, I just love my Fourwinds which is mounted on a 9' SS pole.
I have a Fourwinds also, with the speedbrake too. Just took it off the boat in favor of solar. We cruise in the summer months due to school schedules, so solar makes the most sense to us. I glued folded towel fabric to the frames of the panels and set them right on top of the bimini for now. They are tied down firmly. (We have 130x3 + 120 + 40 watts, a total of 550 watts. On cloudy days I still get a few amps of charging.)
The Fourwinds is back at home, gethering dust, so to speak. We have an extra swivel-connection-thing for the top of the pole too. (Can't get those anymore, I think.) I chose the Fourwinds by motoring around Block Island harbor listening to all the wind generators. I believe I intentionally anchored near a fourwinds, as the winner of that "competition". There are other quiet wind generators out there. My mooring neighbor had a different one that did ok.
Whatever you do, don't buy one of those little-bladed wind generators. In a wind they sound like a Cessna airplane taking off -- for hours on end!
Worth repeating just in case you ever anchor near us...
Regards,
Brad
Instrument rated pilot -- credential provided to back up the (repeated) Cessna comment above.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Wal-mart Wind Turbine crazystrause Gear & Maintenance 7 05-12-2011 09:23 PM
Ampair Pro 100 wind turbine Alegria110 Electrical Systems 0 04-09-2011 10:21 AM
Cheap Wind Turbine generators MacGyverRI Electrical Systems 2 02-16-2011 06:55 PM
Wind turbine.. who is doing what and how? dieselboy Electrical Systems 2 10-05-2009 02:03 PM
DIY Wind turbine generator? sneuman Gear & Maintenance 3 09-14-2004 03:44 AM
