Battery Switch with ACR - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 7 Old 06-27-2013 Thread Starter
One of None
deniseO30's Avatar
I want, or need to replace my battery switch when I get around to doing the Bue Sea ACR installation? It's a bit bewildering! Which one of the MANY Blue Sea makes? I do know I want to get AWAY from 1-2-both off
This one? Model #: 6011
My last project!
deniseO30 is offline
post #2 of 7 Old 06-27-2013
Stu Jackson's Avatar
Re: Battery Switch with ACR
Denise, that switch is the LAST one you should consider. All it does is combine a good bank with a bad one. You really should consider leaving your 1-2-B switch.
Here's why:
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
In addition, here's a story about why the dual circuit switch is NOT such a good idea:
AGM Battery Issues and the Blue Seas Dual Circuit Switch (from Maine Sail) "DARN AGM Batteries"
Darn AGM Batteries - SailboatOwners.com
Once you relocate your AO to your house bank when you install the ACR, the 1-2-B switch is just what you need.
Glad to save you some $$.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 7 Old 06-27-2013
Maine Sail's Avatar
Denise,
While the Blue Sea DCP switch is "easy" it lacks the safety, isolation and redundancy of the 1/2/BOTH that most boats already have installed. I do install those switches but mostly on small center console or walk around fishing boats.
Also I find the vast majority of professionally or DIY installed DCP switches are installed incorrectly on cruising sailboats. A proper installation on deeply cycled banks where one bank is significantly larger than the other has the alt run to the house bank NOT to the starter bank.
A properly wired and used 1/2/BOTH is not a bad switch but it is often misunderstood and misused.
If you feel you must have a dedicated starting battery then I much prefer two independent ON/OFF switches with a third "emergency parallel" switch. Properly wired this allows all the safety, isolation and redundancy of the 1/2/BOTH yet you get a dedicated start and house bank...
With the DCP you have only one option with a bank failure and that is to combine a good bank with a bad one. Not a great plan....
An ACR or battery to battery (B2B) charger, like an Echo Charger, can be installed with any battery switch.
Do some reading on the links Stu gave you...
SVAuspicious likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 7 Old 06-27-2013 Thread Starter
One of None
deniseO30's Avatar
Thanks Gents, I will go back and read them again. So my existing switch can stay, that's good ..and 30-50 bucks I don't have to spend. That lets me have the $ for the voltmeter and some line fuses now.
I need to get over the fear of working 12 volt systems LOL Gawd, I don't think twice about working on 480 volt 3 phase Air conditioning units!
My last project!
post #5 of 7 Old 06-28-2013
Mermaid Hunter
SVAuspicious's Avatar
I agree.
On a related note, when installing a high output alternator, I also like to keep the OEM alternator if at all possible. The small alternator charges the start battery and the HO alternator charges the house bank. It works well, provides online redundancy, and the emergency parallel switch serves to bring either alternator up on both banks.
SVAuspicious is offline
post #6 of 7 Old 06-28-2013
Maine Sail's Avatar
Originally Posted by SVAuspicious View Post
I agree.
I have done a number of these installs and agree. However, they can get very, very expensive if you don't DIY the project. Even if you DIY it can get a lot more costly than simply carrying a spare alt or regulator that could be swapped out in about 15-20 minutes.
Many boats these days lack the physical room in engine bays to even add engine driven refrigeration let alone the fitment of two alternators, the custom brackets and the forward offsets for a single v-belt plus a dual pulley or serpentine kit.
Also the engines these days are getting dainty and finding solid engine block to mount a 150A to 200A + alt to is pretty scarce. This often means mounting to the engine stringer, which I won't do, or custom fabricating new engine mounts with enough meat for an alt bracket. For some engines there are secondary alternator mount kits but they can get very costly too and the alignment is not always a guaranteed thing even with a "kit". Care also needed to be taken in the design stages of engine servicing and access. I see too many custom brackets that leave an owner with little to no access to some critical areas of the engine such as t-stats... R&Ring an alt bracket to swap a t-stat is simply crazy but on one boat that is what had to be done because the install was poorly thought out and rather poorly executed too..
With the advances today in wind, solar and other means of charging, and the reliability of HO alts, when installed properly, most of my cruising customers are now simply opting to carry a spare of the HO alt and a regulator as it simply costs less than the installation of an entire second alt bracket, the custom pulleys and the additional labor involved to install it, paint it and properly fit & align it.
The last one I did ran more than twice the cost of a spare HO alt and a spare regulator and I passed through the custom bracket & pulleys at my costs.... The custom made bracket required many man hours of templates, mock ups, measurement, machining, fabrication and fitment and the custom machined pulleys made the proper alignment of both alts extremely tedious.
In a perfect world this is a great solution/option but we don't always live in a perfect world. Unfortunately most of the secondary alt installs I see are under designed and often grossly misaligned thus emptying the owners pockets for no real gains. Correcting these alignment issues is often tedious and time consuming requiring more machining and fabrication. Once done right they are great but they are not inexpensive to do well, right or correctly.
If one chooses to go this route please be PATIENT and take the time to do it right. On one engine they bolted the custom made bracket to the gear case (in an attempt to get alignment with the crank I assume) and literally cracked it.. It left the owners dead in the water. A spare alt would have been a far easier swap out and a lot less expensive than the huge expense of replacing the gear case. Of course that job could have been done right, and that never would have happened, but it was quite cobbled together as many are that I see....
______
post #7 of 7 Old 06-28-2013 Thread Starter
One of None
deniseO30's Avatar
Expensive is an understatement MS! I'm still slowly picking up parts and pieces to do the project right.
My last project!
Battery Charger and Battery Switch lobosolo98 Electrical Systems 11 10-10-2012 10:34 AM
Battery switch Patbarbeau Gear & Maintenance 20 04-22-2012 09:31 PM
Battery Switch njadventure Electrical Systems 13 04-17-2012 01:56 PM
Battery Switch GrumpyPawPaw Gear & Maintenance 11 07-25-2011 10:39 AM
Battery cut-off switch SothernDragon Electrical Systems 29 06-01-2011 10:53 PM
