Color of wire between batteries in series? - SailNet Community
 6Likes
post #1 of 17 Old 07-01-2013 Thread Starter
Learning to sail
I'm replacing my single 12v group 24 battery with two 6v GC2s in series. This is clearly a little silly, but what color wire should connect the positive of the low battery with the negative of the high battery?
The main interest is in minimizing confusion, so someone doesn't someone mix up the terminals somehow in the future, or something.
I tried googling, and there's not a lot of hits, but there were a couple of google images showing people using a red wire. I guess this makes sense, from the perspective that red means non-zero ideal potential.
aaronwindward is offline
post #2 of 17 Old 07-01-2013
Wandering Aimlessly
PBzeer's Avatar
Re: Color of wire between batteries in series?
Since you're only using two batteries, thus only one wire between them, with the red lead (Pos) and black lead (Neg) clearly attached to their proper terminals, the wire between batteries should not cause any confusion.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #3 of 17 Old 07-01-2013
In serial config, there will need to be a wire run from one battery's neg to the others pos. I think this is the OPs question.
Answer... it doesn't really matter, but I prefer red. Therefore, you can write in a sharpie right on the cable to identify where it belongs in the future. First write an A on one battery and B on the other. Then, for example, write A- on one end of the red connector cable and B+ on the other, or whatever you need.
Jeanneau 54DS
Minnewaska is offline
post #4 of 17 Old 07-01-2013
I agree, red indicates a live wire, and yours is live - at 6V. Red also indicates danger in that anything at ground that touches it will short out the battery. So two votes for red.
kentobin likes this.
MarkSF is offline
post #5 of 17 Old 07-04-2013
Neosec's Avatar
I like to use red wire and then put a few wraps of black electrical tape on the end that connects to the Neg. terminal just for quick visual reference.
Neosec is offline
post #6 of 17 Old 07-05-2013 Thread Starter
Learning to sail
I ended up using red, but I think adding electrical tape like Neosec says is a pretty good idea.
post #7 of 17 Old 07-05-2013
Maine Sail's Avatar
______
-Maine Sail / CS-36T
Maine Sail is offline
post #8 of 17 Old 07-20-2013 Thread Starter
Learning to sail
Maine your installations here and on that other thread are beautiful. Mine isn't anywhere near that awesome, although it's given me some good examples to work toward.
I ended up going with the red, the clear winner; the next time I work on the wiring, I'm going to copy your trick to use colored tape to mark it specially so it's obvious what it is.
post #9 of 17 Old 07-20-2013
Mermaid Hunter
SVAuspicious's Avatar
It's not tape - it's shrink. The wire insulation color isn't that important, but I definitely agree on using properly colored heat shrink. It helps keep things straight. Similarly, once you pick an insulation color you should be consistent.
SVAuspicious is offline
post #10 of 17 Old 07-22-2013
Last one I did we used yellow cable. Red adhesive heat shrink on positive, black on negative. Made it easy to figure out looking at it.
Jgbrown is offline
Land Rover Confirmed as One of Two Series Main Partners to the Extreme Sailing Series NewsReader News Feeds 0 04-30-2013 07:20 PM
Ocean series vs cruiser series scuppersinspired Bavaria 2 04-26-2012 07:43 PM
4 solar panels - series, parallel or series-parallel ArgleBargle Gear & Maintenance 1 04-26-2011 08:27 AM
Batteries--series or parralel? Anjinsan Announcements and Suggestions Box 12 03-09-2010 12:29 PM
NMEA wire color badsanta Gear & Maintenance 10 05-27-2008 08:48 PM
