Electrical box for AC outlet? - SailNet Community
post #1 of 4 Old 07-03-2013 Thread Starter
Learning to sail
What sort of electrical box do I need for an AC outlet on a boat? Can I buy a standard thing from a hardware store, or should it be marine-grade or waterproof or something?
West Marine sells GFCI outlets like these: MARINCO GFCI Duplex Outlet at West Marine
But I don't see any obvious sort of thing on their site to use for an electrical box with it.
aaronwindward is offline
post #2 of 4 Old 07-03-2013
kd3pc's Avatar
Re: Electrical box for AC outlet?
As long as the outlet will be "inside"....a hardware store box is just fine, as is the outlet itself. There is no need to pay the "marine" store premium. IF you have room, an oversize box is easier to use, or an extension ring on a standard box, similarly will give you a little more room in the box.
In the weather outlets, need better protection, that is a box and weatherproof cover that match the socket....same with the wiring connections.
kd3pc is offline
The Following User Says Thank You to kd3pc For This Useful Post:
aaronwindward (07-03-2013)
post #3 of 4 Old 07-03-2013 Thread Starter
Learning to sail
OK great.
With regard to the outlet itself, I would presume that one made for marine use would use corrosion-resistant materials or tinned conductors or something. But I see no indication (on the web, at least) that this is actually the case.
post #4 of 4 Old 07-04-2013
mitiempo's Avatar
I looked at the Marinco GFI on a boat this evening. It was not installed yet. It looks identical to the home depot versions and Marinco doesn't say otherwise. Marinco is just a reseller for this product (and many others), I will continue buying the household GFI's, which do not corrode in any visible way in my experience.
As far as a box, use plastic not metal. Buy a home depot one deep enough for a GFI and cut the extensions off that are designed for nailing to studs.
Brian
mitiempo is offline
EFI Outlet in cockpit. Rasputin Electrical Systems 35 06-19-2013 07:12 PM
12v DC outlet installation kwaltersmi Electrical Systems 7 08-24-2010 11:40 AM
Loo outlet location Classic30 Gear & Maintenance 10 08-05-2010 09:05 PM
Fried Outlet? newportknots Gear & Maintenance 2 08-25-2008 08:17 AM
Diagnosing/solving electrical outlet issue jmunson2 Gear & Maintenance 55 06-02-2007 04:43 PM
