How to use marine battery posts? - SailNet Community
 2Likes
  • 2 Post By mitiempo
post #1 of 9 Old 07-04-2013 Thread Starter
Learning to sail
My boat came with all wiring only connected to the threaded terminals; nothing connected to the lead automotive-style tapered SAE posts. Everything that wired direct to the battery stacked on the threads.
Is there anything in particular that the big lead terminals should be used for? Or should I just keep them covered and ignore them?
I've bought new batteries and I'm redoing some of the wiring, and adding a permanently wired AC charger. There is no starter motor or anything; all of the loads are electronics, which the biggest being the inverter or the autopilot, and of course the charger itself.
aaronwindward is offline
post #2 of 9 Old 07-04-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: How to use marine battery posts?
A good question.
They are there as an alternative to the threaded terminals, so in your case, just cap them off and ignore tham. It's important to cap them or cover them in some way, especially the red (+) because if anything heavy and metallic falls across them whilst out sailing nasty things could happen..
Classic30 is offline
post #3 of 9 Old 07-04-2013
mitiempo's Avatar
I agree, cap them and ignore. But there should not be multiple connections stacked on the studs of the battery. Invest in a few busbars and then you can have less connections on the battery. Ideally there should be only one positive and one negative on a battery, excepting temp sensors and any parallel/series wiring.
Brian
mitiempo is offline
post #4 of 9 Old 07-04-2013
Classic30's Avatar
Dock
..and charging circuits and voltage monitoring and...
post #5 of 9 Old 07-04-2013
mitiempo's Avatar
Can all be done from the bus a few inches away. One of the last larger banks I installed was composed of 8 golf carts in series/parallel - 960 AH. Except for the series/parallel wiring there was one positive and one negative out to their respective buses or fuses and one temp sensor.
Classic30 and chef2sail like this.
Brian
mitiempo is offline
post #6 of 9 Old 07-05-2013 Thread Starter
Learning to sail
Would there be any value in putting charging on the SAE posts? It's pretty much the highest current load I currently have, at 40A; it's also 'special' in that it doesn't go through the main bus, but directly through a 50A fuse to the charger (so the wire run has as little drop as possible).
post #7 of 9 Old 07-05-2013
Maine Sail's Avatar
Amen! These are what most of my installs typically look like.
In this situation I used the "auto" post for the MRBF fuse and main + feed to the vessel. The marine post was used for the parallel connections.
During the mock up stage of the battery box:
I am usually starting with something like this:
______
-Maine Sail / CS-36T
Maine Sail is offline
post #8 of 9 Old 07-07-2013
Classic30's Avatar
Dock
No. Actually the highest current load is usually either engine starting or anchor winch load (don't know if you have either).
Having the charger connected to the main battery bus, with everything else, makes it easier to work out your cable connections and means you don't need a second battery protection fuse..
post #9 of 9 Old 07-21-2013
And as you can see from Maine Sails pictures you should NOT use the wing nuts that sometimes come with the secondary battery connections. I was dinged by my insurance survey for having wing nuts and was recommended to replace them with locking nuts.
CapnRon47 is offline
marine battery and a good charger jhgreen Gear & Maintenance 2 08-18-2012 09:40 AM
favourite marine battery floridajaxsailor Gear & Maintenance 39 04-29-2012 10:37 PM
Marine battery group size whats the difference??? saurav16 Gear & Maintenance 17 08-29-2009 05:17 PM
Marine Battery Weigh in saurav16 Gear & Maintenance 11 07-31-2009 08:07 AM
Marine Battery Ratings Ralph Doolin Gear and Maintenance Articles 0 01-15-2002 07:00 PM
