12 volt in parallel - SailNet Community
 1Likes
  • 1 Post By xort
post #1 of 3 Old 07-12-2013 Thread Starter
SSBN506's Avatar
12 volt in parallel
Hi Everyone,
I have two 12 volt batteries in parallel on bank 2 and one starting battery on bank 1 on my Catalina 30. The starting battery is new. The two battery's on the house bank are from PO and not in the best shape.
One battery is a 70 amp hour under the navigation table and the other is a big 150 ish (cant recall) under the cockpit birth.
My question is when I replace them is it ok to mix batteries with different amp hours like that in parallel? I have found mixed information?
I may also go 6 volt in series but for this post I am just looking at my 12 volt options.
SSBN506 is offline
post #2 of 3 Old 07-12-2013
chucklesR's Avatar
Re: 12 volt in parallel
Batteries in a bank should be the same size - you risk overcharging/undercharging and premature 'death' of the batteries.
chucklesR is offline
post #3 of 3 Old 07-13-2013
Please buy nigel calders book 'boatowners mechanical and electrical manual'. Excellent information on everything you need to know in fairly easy to digest terms
chef2sail likes this.
xort is offline
Replacing 12 volt batteries with 6 volt justonemoreproject Electrical Systems 11 03-15-2012 09:13 PM
4 solar panels - series, parallel or series-parallel ArgleBargle Gear & Maintenance 1 04-26-2011 08:27 AM
Mixing 6-volt and 12-volt Batteries? captainfrank Gear & Maintenance 3 11-08-2008 11:33 AM
12 volt to 24 volt conversion SMIK12 Gear & Maintenance 1 04-18-2005 01:50 PM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 05:41 PM
