Onan cooling problem - SailNet Community
post #1 of 5 Old 07-12-2013 Thread Starter
Having problem with a 5.5kva 2006 model Onan. Gathered from former owner all worked OK, recently serviced - heat exchanger serviced, coolant side of cooling system flushed through, impeller and belts changed - service engineers who have been doing this for 20 years cannot get coolant to circulate! Looked at all the obvious things again, impeller, thermostat, blockages incl mechanics cloths - run out of ideas. Any thoughts really appreciated please.
nmit5903 is offline
post #2 of 5 Old 07-13-2013
ebs001's Avatar
Re: Onan cooling problem
Buy a digital infrared heat gun. This will allow you to see any blockages.
Did you bleed the T'Stat?
Try removing thermostat and run without one. Drain coolant side. Then remove hoses from cooling reservoir. Use a garden hose with a cone shape spray nozzle, the old fashion kind, inserting the nozzle one of the coolant hoses. Turn on the water and it should come out the other hose without a problem. Then do the same thing in the other direction. Put everything back. Fill coolant side with water until you know everything is working fine, then you can drain and refill with coolant If you still have a problem your water pump may be the cause.
Isolate the pump as much as possible and try running water through it using the pump.
ebs001 is offline
post #3 of 5 Old 07-13-2013 Thread Starter
Thanks. Will try that.
nmit5903 is offline
post #4 of 5 Old 07-16-2013 Thread Starter
The lads found that the coolant system was partially blocked with a jelly like substance -bit like wood glue - white colour. I have seen a post somewhere on this. They have never seen it before? Any thoughts?
nmit5903 is offline
post #5 of 5 Old 07-17-2013 Thread Starter
Head now off and jam packed full of jelly like material. Think it is the combination of salt water contamination of fresh water cooling system, no doubt some corrosion as a result of salt/aluminium, different coolants over years of cruising to distant parts and no doubt the overheating that resulted.
Hopefully now back on the way to being operational again.
nmit5903 is offline
Yanmar raw water cooling problem noreault Diesel 18 04-15-2014 07:37 PM
1GM10 cooling problem.... again! Captain Aubrey Gear & Maintenance 8 06-25-2013 09:20 PM
water in oil onan generator bluwateronly Diesel 7 01-15-2012 12:29 PM
Onan Genset on Amel Super Maramu Ad Lib Gear & Maintenance 0 07-20-2011 09:48 AM
onan generator-electrolosis kimberlt Gear & Maintenance 0 05-15-2005 07:09 AM
