Quad-Cycle regulator system and/or parts - SailNet Community
post #1 of 2 Old 07-25-2013 Thread Starter
Looking for Quad-cycle system ands/or parts made by Cruising Equipment Co. in Seattle 1988 1996 or so. (Needx circuit boards, ribbon cables, display unit.
nepple is offline
post #2 of 2 Old 07-30-2013
Maine Sail's Avatar
Re: Quad-Cycle regulator system and/or parts
You may want to consider a newer regulator such as a Balmar. These were odd systems with some glitchy behavior. When Heart Interface bought them they made some slight changes but they still are rather glitchy. I replace quite a few HI and CE regs (just replaced a CE Alpha last week) but they usually just go right into the dumpster. There is a reason Xantrex now has Balmar build their regulators and why they dumped the old CE/HI stuff that they bought....
You don't need the regulator portion to keep the battery monitor portion working, if it still does.... Next time I replace one I will keep some parts but they are usually so dead that it is not worth keeping anything.
______
-Maine Sail / CS-36T
Maine Sail is offline
autohelm ST50 system can I use ST60 parts? NewportNewbie Electronics 3 10-23-2013 01:56 PM
Wanted Stern furling system #8 parts ariasis1 Gear & Maintenance 3 04-01-2011 10:52 PM
CruisAir system freezing up on heat cycle BigMoe Gear & Maintenance 5 05-13-2009 10:29 PM
B&G net Quad problem Iason Electrical Systems 0 02-12-2009 07:32 PM
Rush-hour fender bender delays Quad-Cities? arrival in California (Quad-City Times) NewsReader News Feeds 0 05-06-2006 03:15 AM
