Helm control panel question - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 08-06-2013 Thread Starter
dem45133's Avatar
Re: Helm control panel question
Humm, don't know... I'll have to investigate that.
1980 Seafarer Swiftsure 30
1978 Bayliner Buccaneer 270 (now sold and being restored in FL)
1962 SeaMac 14' Plywood Runabout, mahogany decked, with 1959 Evinrude 35 Big Twin (owned since age 17, I'm now 60)
dem45133 is offline
post #12 of 14 Old 08-06-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Like dem; I'm in the same boat. Starboard, aft lower bulkhead shift and throttle and opposite bulkhead engine indicators. The trans and throttle get in the way, lines get tangled and are subject to being kicked or toe-stubbed. Idiot lites are near useless and IF I hafta shut down, I gotta drop to a knee and find the button.
I plan to add all he gauges I need , the throttle/shift and such to the starboard/aft cabin bulkhead; like the pilots station onna Pilothouse boat. Now just to find the dual control and appropriate meters!
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #13 of 14 Old 08-06-2013 Thread Starter
dem45133's Avatar
Interference of the magnetic compass... could that be one of the reasons for scattering electrical based devices around the cockpit? Mechanical engine gauges do not operate off electrical signals so I may simply use old school tech on them. I'll have to see if Farryman built any mechanical tach drives into their mid 70s engines.
I just read an article in "Good Old Boat" (July Aug 2013, pg 55) where compass interference from an on board generator caused as much as a 40 degree error... they ended up sailing into a rock wall of a coast in Turkey (I think it was Turkey)... but then a generator, especially if it contained permanent magnets likely should have never been installed just below the compass (that wasn't well defined in the article, but wasn't very far away evidently from the wording). If it was electromagnetic field "magnets"... the magnetic fields would collapse once de-energized and then not effect the compass (I believe, could be a residual... I'll ask my Uncle). But with permanent magnets the mag field would always be present. Either of these are very strong magnetic fields compared to modern electronic instruments so I'll be investigating over time on this and post when I know more.
All knowlegde and experiences for all of you is more than welcome.
I'll be in the Great Lakes initially where its not likely quite as critical, but after retirement who knows where I'll sail it.
Dave
dem45133 is offline
post #14 of 14 Old 08-06-2013
manatee's Avatar
If you carry a pocket compass when you're shopping, you can check whether anything you're considering has a magnetic footprint. Shielded cable may tame the electromagnetism of guages,
but the instruments may leak. Remember the inverse-square law; even a little extra separation
can significantly reduce interference.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
Helm Control spec2 Seamanship & Navigation 19 08-30-2010 02:20 AM
Troubleshooting LPG Control Panel RainDog Gear & Maintenance 7 09-28-2009 12:52 PM
A/C and Heating control panel pimhof Bavaria 0 03-02-2009 11:57 AM
heeling, weather helm and rudder control Randolph Bertin Learning to Sail 20 09-06-2004 07:03 AM
