understand 12v electrical - Page 3 - SailNet Community
post #21 of 24 Old 08-12-2013
Re: understand 12v electrical
Battery Maintenance Facts
State of Charge Specific Gravity Voltage - 12V Voltage - 6V
100% 1.265 12.7 6.3
75% 1.225 12.4 6.2
50% 1.190 12.2 6.1
25% 1.155 12.0 6.0
Discharged 1.120 11.90 6.0
* Sulfation of Batteries starts when specific gravity falls below 1.225 or voltage measures less than 12.4 (12v Battery) or 6.2 (6 volt battery).
kentobin is offline
post #22 of 24 Old 08-12-2013
mitiempo's Avatar
100% 1.265 12.7 6.3
75% 1.225 12.4 6.2
50% 1.190 12.2 6.1
25% 1.155 12.0 6.0
True, but a 20 hour test brings the battery down to 10.5 volts. The load should be 5% of battery or bank size for accuracy. If you can't get it exact don't bother trying - you already have an inaccurate AH estimation and don't need another one.
I don't expect the issue to be the batteries, but the monitor.
Brian
mitiempo is offline
post #23 of 24 Old 08-13-2013 Thread Starter
SSBN506's Avatar
Originally Posted by chucklesR View Post
Put it back to 232 AH, run a equalization process via your charger (overcharge them on purpose)... and above all else do some reading on how batteries work.
If I can learn it, so can you.
That is what the reseller of the batteries suggested after talking to them. I have been doing a lot of reading on how batteries work but thanks for that sugestion also.
SSBN506 is offline
post #24 of 24 Old 08-14-2013
Stu Jackson's Avatar
Ample Power Company Home Page, tech tab, download the Ample Power Primer, everything you need to know about batteries for boats.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Because some of you will understand (sailing with dog related)... josrulz General Discussion (sailing related) 9 10-25-2011 09:08 AM
Trying to understand boat registration nsweeting General Discussion (sailing related) 8 09-30-2011 04:54 PM
