Another Battery Hookup Question - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Electrical Systems
Old 08-10-2013
JoeLena's Avatar
JoeLena is on a distinguished road
I know, I know; there are a lot of these questions, but none gave me the feeling I knew with certainty how to hook up the batteries correctly, and I would like to get this right.
Hooking up 2 group 27 batteries and using a solar panel with a charge controller.
1. From the controller, do I connect the red lead to red on one battery and the black to the other one?
2. The positive from each battery only goes to the switch, the positives from each battery is not connected to each other.
3. The negatives of the 2 batteries are connected to each other, as well as the main ground?
Here's a diagram, am I way off?
'72 Catalina 27 Tall Rig #519
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 08-10-2013
Capt Len is on a distinguished road
Re: Another Battery Hookup Question
Your either/neither/ both switch has to be on both for that to work fully. Others will be along soon to explain.
  #3
Old 08-10-2013
JoeLena's Avatar
So the positive would be connected. So how would it need to be to charge correctly?
  #4
Old 08-10-2013
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
You can keep it simple by running the solar charge controller to the house bank (#2). That will only charge #2, unless you put the switch to the "both" position, at which point it will charge both.
But unless you are doing separate switching, there's no really simple way to charge them both from one controller while still keeping them isolated.
If you want to add more stuff, sure, you could charge #1, add in a battery combiner, and then that would connect #2 automatically to let it charge up whenever #1 was full (engine running or solar topped up) but that's going to be an extra $100+.
  #5
Old 08-12-2013
redline is on a distinguished road
Another thing to check/beware: my solar charge controller (a BlueSky SB3024IL) has SEPARATE negative connections for battery and panels - they must not be connected together or reversed (used for current monitoring I believe). Check your manual.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
  #6
Old 08-13-2013
Large Member
mdbee is on a distinguished road
If you have isolated batteries you could use a MorningStar SunSaver Duo which is basically two controllers in one. You will have two sets of wires. One set to each battery.
I don't have the Duo model without the remote meter showed on my website but it is available. In the past, the one with a remote meter has been the most popular. MorningStar has told me that it will also work if you have the switch turned to both batteries.
Info:
Controllers
  #7
Old 08-13-2013
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Put a combiner between the two batteries (like THIS). Charging them by switching the main switch to BOTH isn't a good idea, as the batteries are bound to have different potentials.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
You may post attachments
You may edit your posts
Solar Charge Controller and Battery Hookup sailtobike SailNet FAQ 9 06-18-2011 06:20 PM
Battery AMP Question dougshipl Gear & Maintenance 11 04-27-2010 08:34 AM
Battery hookup for Outboard Engine dmkey Electrical Systems 1 08-29-2009 03:35 PM
battery question northstarjim Gear & Maintenance 14 07-01-2008 05:55 AM
House and Starter battery hookup gmenrule Gear & Maintenance 7 06-10-2006 07:21 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
