Partially damaged battery? - SailNet Community
post #1 of 2 Old 08-23-2013 Thread Starter
Recently my alternator's "sensing" input became unplugged yielding what I expect to be a constant 16v output..whoops. When I recently spent 5 hours motoring back (due to storm damage to my sails) I got that sulpher smell that indicates one is cooking their battery -when it rains it pours. So I turned off the engine to let everything cool down. Is it safe to keep using this battery? Currently it holds a charge (12.6 ish after charger is off). However, my 3 stage charger never switches from the "absorb" to the "float" stage.
Reefpoints is offline
post #2 of 2 Old 08-24-2013
Stu Jackson's Avatar
Re: Partially damaged battery?
Since we're not there on your boat with you, only YOU can figure out the condition of the batteries. Check the case, check the water levels, disconnect the charger(s), let it sit for at least 24 hours and use a hydrometer. Most likely toast, although if there's still proper water levels, just consider it an equalization! Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Damaged Bow Pulpit talessi Newport 4 03-19-2013 08:54 PM
Workers scramble to save partially submerged sailboat - WFTV Orlando NewsReader News Feeds 0 02-22-2013 05:20 PM
Partially filling a void jarcher Gear & Maintenance 9 01-11-2013 01:19 PM
Reverse only partially engaging scove Diesel 9 01-25-2011 09:52 PM
I will be partially unavailable Cruisingdad General Discussion (sailing related) 11 03-11-2009 10:20 PM
