1/2/Both switch is AFD wired, but to where? - SailNet Community
 1Likes
  • 1 Post By WoobaGooba
post #1 of 8 Old 09-04-2013 Thread Starter
WoobaGooba's Avatar
The alternator on my Yanmar 3GM30F is an Hitachi LR155-20 which is internally regulated. My Guest 1/2/Both switch has two small-ish posts marked field disconnect, with wires attached. Any idea where these might be going? The alternator looks to be wired as expected: E, BAT, and two smaller wires going to the instr panel. No sign of any field disconnect wires at or near the alternator.
Thanks much!
WoobaGooba is offline
post #2 of 8 Old 09-04-2013
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Re: 1/2/Both switch is AFD wired, but to where?
See this link Alternator Field Disconnect - Blue Sea Systems for a good explaination
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #3 of 8 Old 09-04-2013
Maine Sail's Avatar
Perhaps they are using the AFD to break another load or your alt has been wired for external regulation and the wires run to an ext regulator.... AFD only works if you have access to the regulator field wire or the regulators B+ / excite wire..
The AFD works by disconnecting the alt field microseconds before you dump the load. It is designed to protect the alternator diodes from a load dump. There are better ways to prevent fried diodes but this is one of them..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 8 Old 09-04-2013 Thread Starter
WoobaGooba's Avatar
Thanks zephr and MainSail.
I've seen the BlueSea AFD primer, no joy there. As MainSail pointed out, my alternator is internally regulated. Checking my Yanmar shop manual wiring info AND visually inspecting the back of the alternator confirms internal regulation.
Alternator wiring.
BAT post is wired to the starter + post.
E post is wired to ships ground.
Below BAT post are the L and R which run to the engine instr panel.
No Field wires to be seen anywhere.
But there is an unconnected set of wires run for a never installed battery charger. Heavy gauge red (2) and black(1). I think I also saw two unconnected light gauge wires... would the AFD wiring on the battery switch ever be connected to an AC battery charger?
post #5 of 8 Old 09-04-2013
Maine Sail's Avatar
Here is a pic of the back of the alternator ...
BAT post on the left, which is wired to the starter + post.
E post on the right, wired to ships ground (smaller wire to instr panel -)
You'll want to trace them back and find out where they go... You never know what you'll find on boats so best to map out your system so you know and understand it....
______
post #6 of 8 Old 09-05-2013 Thread Starter
WoobaGooba's Avatar
Yes, agreed. Time to trace these wires and map out the rest of the electrical system. Thanks
post #7 of 8 Old 09-30-2013 Thread Starter
WoobaGooba's Avatar
Answer is ... nowhere! Boat's manual does not match actual 12BO switch wiring (nothing attached to the AFD terminals).
jimgo likes this.
post #8 of 8 Old 10-02-2013
You might want to try doing a continuity test between the excite (red/black) wire at the back of the alternator and the two wires connected to the field disconnect at the switch. It's entirely possible that someone re-routed the wire from the oil pressure switch through the field disconnect before taking it to the internal regulator's excitation circuit.
fidalgo is offline
wireless vs wired fjcruiser Electronics 10 05-23-2013 11:52 AM
Wired Up My Mast Squidd Gear & Maintenance 4 03-20-2012 05:31 PM
Nexus instrument wired remote broke extremo Gear & Maintenance 1 01-31-2012 11:55 AM
mast is wired - do I need to redo part? LookingForCruiser Gear & Maintenance 8 06-21-2009 06:33 PM
Radio antenna connector wired wrong?? FishFinder Gear & Maintenance 7 07-06-2008 06:48 PM
