Do I need a battery charger? - Page 2 - SailNet Community
post #11 of 15 Old 10-21-2013
Re: Do I need a battery charger?
Any recommendations, I have already looked @ the ;
Morningstar SG4...
rnuzzolo is offline
post #12 of 15 Old 10-21-2013
BarryL's Avatar
Hey,
Before you buy anything why not use the boat for a month or two and see how it goes? if you run your engine to get in / out of the harbor, that may provide enough power. My boat has been on a mooring forever and my batteries stay charged. I use my boat 1-2 times a week, motoring in and out of the harbor for 10-15 minutes each way. My electrical use is pretty minimal: I run a 5' chart plotter, VHF radio, depth, wind, speed instruments and an autopilot, that's about it. My batteries get charged enough from my alternator.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #13 of 15 Old 10-22-2013
I have just completed my first season (new to sailing) with the boat and have not had an issue with the batteries. I do go a week or two sometimes not using the boat, but not being able to crank the engine when I need to is one of my concerns.
I have owned power boats for 25 years but they were always docked with charger running.
Thank you for the feedback.
Rich
rnuzzolo is offline
post #14 of 15 Old 10-22-2013
chucklesR's Avatar
Wet cell batteries can loose 2% a month with self discharge, 2-3 weeks of sitting on a ball will be meaningless provided you charge the batteries on the way in and they are always at least 80-90 percent full.
If winter is a non-sailing time where you are then you will need to be SURE they are topped off prior to lock up - and you better be sure your bilge is normally dry or you have the amp hours to keep it dry.
Simple, low watt and low cost solar is the way to go - no sense having a couple hundred bucks in batteries die out because you wanted to scrimp a buck on a charger.
chucklesR is offline
post #15 of 15 Old 10-22-2013
asdf38's Avatar
Morningstar SG4...
Genasun makes a nice line of smaller ones. This is what I have.
Genasun GV-4-Pb-12V, 4A MPPT controller for 12V Lead Acid Batteries
asdf38 is offline
battery bank dual charger or triple charger? mbaillie Gear & Maintenance 23 06-29-2013 09:16 AM
Battery Charger and Battery Switch lobosolo98 Electrical Systems 11 10-10-2012 10:34 AM
New Battery charger (unplugged) causes spark on battery post!! Northeaster Gear & Maintenance 15 11-17-2008 08:30 PM
battery charger seamyst Gear & Maintenance 16 10-25-2007 09:05 PM
Sizing a Battery Charger for Windlass Battery btrayfors Gear & Maintenance 9 04-11-2007 12:43 AM
