-   Electrical Systems (http://www.sailnet.com/forums/electrical-systems/)
-   -   wiring diagram and questions (http://www.sailnet.com/forums/electrical-systems/103498-wiring-diagram-questions.html)
boz86 09-09-2013 12:28 PM
I've perused hundreds of pages, and I think I understand now. One question, when you add the wind generator, solar panels, shore battery charger, and alternator pos(+) and neg(-) do you terminate them at the appropriate house battery terminals? In other words, in my example you'd essentially have four inputs and one output at the house bank pos and neg terminals. Correct?
Each of the supply lines has a diode or something to keep the other generation sources from harming it?
https://lh6.googleusercontent.com/-A...dc+diagram.jpg
mitiempo 09-10-2013 12:26 AM
Re: wiring diagram and questions
It is always best to keep the number of wires at each battery post as few as possible. A short jumper from house positive to a bus where the other connections terminate works well. Same with the negative side, remembering that the shunt for the monitor has to be first in line with all loads following after the shunt.
Multiple charge sources are not a problem on the same battery bank.
boz86 09-10-2013 08:38 AM
That's something I hadn't considered yet, much tidier and safer.
That made sense to me, but I wanted to make sure I hadn't missed something in all my reading.
Thanks for the help.
Maine Sail 09-10-2013 08:52 AM
Your batt mon shunt will not work correctly as drawn.
ALL LOADS AND CHARGE SOURCES, INCLUDING THE ECHO, & START BATTERY MUST BE ON THE LOAD SIDE OF THE SHUNT.
NOTHING CONNECTS TO THE HOUSE BANK NEG POST OTHER THAN THE BATTERY SIDE OF THE SHUNT AND ANY BATTERIES IN THAT PHYSICAL BANK...
boz86 09-10-2013 06:11 PM
Thanks Maine Sail, found this thread doing more searching because I didn't want to pester the forum piece by piece:
http://www.sailnet.com/forums/electr...dc-system.html
His was much more exact and correct, but at least building my own diagram let get a handle on my misunderstandings.
Bene505 09-11-2013 07:49 AM
Bravo on having a battery monitor. We have the Victron and it's the best money I've spent -- I look at the dang thing all the time.
I'd advise not using your starting battery as a reserve for "house" usage. If your house bank is getting low, that's exactly the time to start your engine and get some charging. It's not the time to risk your ability to start the engine. I've always thought that "1-2-both" switches are only for the starter circuit. That way you can leverage your house bank if the starting battery goes dead. We don't use one though; we keep a pair of jumper cables onboard.
We needed a diode between our wind genny and the regulator. Actually there is no regulator for a wind genny, only a dump load controller. Wind gennys have to make power or they spin out of control. You'll need a dump load attached to the controller. (Some smaller and hugely noisy wind gennys do stop spinning instead of creating a dump load. They have everything built in too, but will annoy your family/crew and make your neighbors upset with you.)
Even though we typically anchor where there are few neighbors, we ditched the wind genny and added more solar. I'll probably put the Fourwinds II on eBay in the next week or so. It's not windy enough where we cruise and we turned it out of the wind (shut it down) whenever we were on the boat. (It was great as a riding/anchor sail, by the way.)
Regards,
Brad
chucklesR 09-11-2013 08:33 AM
MS has already spoken to the shunt on the wrong side.
I'd add at least a 4 terminal buss bar (150amp rated) to the neg side, maybe to the positive as well depending.
It just makes hooking up all the cables easier and neater.
The positive side should have either a 100 or 150 amp fuse on it as close to the battery as possible.
After the MPPT you should have a fuse rated at 150% of output of the MPPT (for example I have a 30 amp after my 20amp BS 2125 (HV) controller- ditto on the wind gen, put a fuse on it (positive side for both).
Bene505 09-11-2013 06:33 PM
Originally Posted by chucklesR (Post 1087177)
...I'd add at least a 4 terminal buss bar (150amp rated) to the neg side, maybe to the positive as well ...
Skack! :):):)
Regards,
Brad
Stu Jackson 09-14-2013 02:35 PM
You don't need to reinvent the wheel. :)
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
