When to hire a pro... - SailNet Community
 4Likes
post #1 of 16 Old 09-09-2013 Thread Starter
First Mate/Galley Wench
Send a message via Skype™ to diverchick71
Our boat (first-time boat owner unless you count the bass boat) needs some electrical work. The inverter doesn't seem to be working, when I switch the switch, I get no lights, sound, anything. Our outlets work on shore power, but that's no fun. We'd like juice when we actually go sailing and anchor out. (We just bought the boat, needs some rigging fixed before I feel comfortable taking her out) The windlass is fairly new but also not working.
I want to be a DIY...but I know NOTHING about electricity. I have a couple books but they also sort of read like greek to me. Should I just hire someone? Someone that's willing to explain things to me, and follow them around and learn while they are at it? Construction style stuff doesn't scare me...but systems are just a mystery to me.
Never regret something that once made you smile--Me
diverchick71 is offline
post #2 of 16 Old 09-09-2013
Re: When to hire a pro...
electricity is really simple when you take your time to understand it
get yourself a multimeter and work from the battery to the electrical panel, then from the panel to each circuit, as long as there is no break in the wires and no blown fuses, the current will flow.
if you need help, I'm sure many people will chime in to help
start with a pencil and a piece of paper and draw what circuit you can find
jimgo likes this.
fred1diver is offline
post #3 of 16 Old 09-09-2013
I don't discuss my member
Fstbttms's Avatar
If you do want to hire someone, here's your man:
Mathieson Marine
(510) 350-6622
earl@mathiesenmarine.com
Fstbttms is offline
post #4 of 16 Old 09-09-2013
manatee's Avatar
Sign on the wall of a shop:
Labor Rates: $50/hr
If you watch: $75/hr
If you help: $100/hr
If you laugh: $200/hr
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #5 of 16 Old 09-09-2013
Might as well do the basic checks first... like is there 12V power reaching the inverter?
Does the inverter have a breaker? Check that 12V is entering it, and leaving it when it's on!
The best book for an intro to marine electrics that I know of is this one, and it covers other aspects of inspection and maintenance too :
http://www.amazon.com/Caseys-Complete-Illustrated-Sailboat-Maintenance/dp/0071462848
This books is kind of the key chapters from all his books rolled into one. If you JUST want electrics, there's this :
http://www.amazon.com/Sailboat-Electrics-Simplified-Don-Casey/dp/0070366497/ref=sr_1_5?s=books&ie=UTF8&qid=1378765456&sr=1-5&keywords=don+casey
MarkSF is offline
post #6 of 16 Old 09-09-2013
Electrical fires are the number one cause of boat fires, by far. Ironically, 12v systems are more likely than 110v, probably because novices are more likely to play with them.
Nothing wrong with doing your own electrical work, but only to the extent that you know what you are doing. I will do some, but not all.
Jeanneau 54DS
Minnewaska is offline
post #7 of 16 Old 09-09-2013
manatee's Avatar
Another candidate: The 12-Volt Bible for Boats
~~Dylan Winter,
manatee is offline
post #8 of 16 Old 09-09-2013
Asleep at the wheel
jimgo's Avatar
Before you do it on the boat, play with a 12 volt system at home. Get familiar with the concepts, then go aboard and have at it. But I agree with all of the comments above. It's really not that hard, but it DOES have to be done properly or you risk having serious problems.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #9 of 16 Old 09-10-2013 Thread Starter
Thanks for all the great replies. The inverter seems to not be getting juice. I flip the on/off switch at both control panel and on inverter and I get zilch. Two thick wires coming out of the back (red and black) but I'll actually have to remove the inverter to get behind it, it's mounted too closely to the side of the boat. It's mounted under nav station. All things I need to look at when I get back to her. I need to move closer. :-). I have Don Casey's Illustrated Sailboat repair, and Nigel Calder's essential systems. Not knowing what I'm doing and fear of fires is exactly my fear!
post #10 of 16 Old 09-10-2013
A very basic invertor will have wires connected to the 12v DC system and others run to the 110v AC receptacles. More sophisticated systems also have wires connected to shore power, as they double as battery chargers. In order to test them with a multi meter, you need to know which are which. Some should show voltage, even if the invertor is bad.
Invertors do go bad, but its tough to know if its hooked up properly, turned on properly or blew a fuse. The cost of an electrician could be a good education in how your boat is set up. Meet him/her there.
mitiempo likes this.
Jeanneau 54DS
Hire Someone To Do Shear Stripe? swampcreek Chesapeake Bay 1 05-04-2013 07:51 AM
price to hire yacht for a day novicesailerx General Discussion (sailing related) 2 12-22-2010 10:18 AM
Rig Inspection - DIY or Hire someone? Bene505 Gear & Maintenance 35 04-12-2009 07:15 PM
Why hire a surveyor bubb2 Boat Review and Purchase Forum 4 07-28-2008 03:21 PM
