Refrigerator off main breaker? - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 09-30-2013
Glad I found Sailnet
Bene505's Avatar
Re: Refrigerator off main breaker?
Originally Posted by GrahamO View Post
Thanks Brad,
Do you have a switch that allows you to isolate the refrigerator?
Graham
No, I pull the fuse or turn the thermostat off.
(I sometimes have a relay in line with the thermostat, when the bateries hit 13.5 volts, the compressor runs and at high speed. It works great in the summer to store extra energy. When the relay is connected, it means I have to pull the fuse. I ought to make a switch for the thermostat/relay variations, but I'm still not done designing it so the fridge doesn't get too cold.)
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #12 of 16 Old 10-01-2013
Maine Sail's Avatar
I am just installing a new fridge system. The old one is tied to the main breaker but I am considering going direct from the battery through its own breaker so we could leave it on with the rest of the boat off. Is this OK?
It is for long term cruising and we have a very well insulated (4 1/2"+) refrigerator and 400w of solar.
Advice appreciated as always.
Thanks
Graham
Graham,
Sure you can do that but there is always risk. I am not a huge fan of powering loads from only solar or wind when away from the boat for extended periods.
A lot of fridge manufacturers want to see their appliance run straight to the house bank due to so many issues with voltage drop. So long as you have a fuse that meets the AIC rating for your bank you will be fine.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 16 Old 10-01-2013 Thread Starter
GrahamO's Avatar
Thanks MS,
I was not quite clear. The fridge will be off the house bank but not through the main isolation switch. It will have its own isolation switch.
I'm definitely not thinking of extended periods. Just things like going ashore for the day where I would like to turn off the bulk of the electrics but leave the fridge running.
Does that sound OK?
Graham
Graham,
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #14 of 16 Old 10-01-2013
Maine Sail's Avatar
Thanks MS,
Does that sound OK?
Graham
That is fine. I thought you were talking about leaving it on a mooring during the week etc...
______
post #15 of 16 Old 10-02-2013 Thread Starter
GrahamO's Avatar
Thanks MS and thanks for all the other great information you have posted elsewhere. It has been a great help to me. If you are ever down in Portsmouth or Kittery let me know and I will happily buy you a beer or dinner.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #16 of 16 Old 10-02-2013 Thread Starter
GrahamO's Avatar
Brad,
What are you using to voltage control the relay? I was thinking of doing this for the watermaker to make use of surplus solar power.
Graham
Regards,
Brad
Graham and Janaki
Bristol 38.8
GrahamO is offline
refrigerator wavedancer38 Provisioning 15 02-03-2012 01:26 PM
Refrigerator billbalme Pacific Seacraft 7 04-11-2010 02:17 PM
Refrigerator jacobitesc Beneteau 4 02-24-2009 03:17 PM
main breaker rating adamtroyg Gear & Maintenance 28 04-13-2008 07:33 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
