Refrigerator off main breaker? - SailNet Community
 2Likes
post #1 of 16 Old 09-29-2013 Thread Starter
GrahamO's Avatar
I am just installing a new fridge system. The old one is tied to the main breaker but I am considering going direct from the battery through its own breaker so we could leave it on with the rest of the boat off. Is this OK?
It is for long term cruising and we have a very well insulated (4 1/2"+) refrigerator and 400w of solar.
Advice appreciated as always.
Thanks
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #2 of 16 Old 09-29-2013
Re: Refrigerator off main breaker?
You should have a main breaker that feeds all the sub breakers, for which one could be dedicated to the fridge. Everything else should go through other sub breakers, so that anything can be isolated, but everything can be killed by the one master in the event of an electrical fire.
olson34 and rikhall like this.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
Maine Sail (09-29-2013)
post #3 of 16 Old 09-29-2013
One of None
deniseO30's Avatar
Need, more information! Guessing it's only 5 amps but more importantly; use the right size wire!
My last project!
deniseO30 is offline
post #4 of 16 Old 09-29-2013
mitiempo's Avatar
This is DC so a main breaker is not needed - the house bank main fuse takes care of that before feeding the DC panel. It is common to have a few "always on" circuits, bilge pump for one and the refrigeration can also be one. These are best fed from a sub panel that is not main switch dependent. A small panel or a fuse block works well. The feed wire to this panel or fuse block should be appropriately fused for the wire size leading to it. If desired a switch can be installed in this wire so total isolation is possible.
Brian
mitiempo is offline
post #5 of 16 Old 09-29-2013 Thread Starter
GrahamO's Avatar
Thanks guys,
I am planning battery to 30amp fuse to 30amp+ switch to refrigerator compressor. The wiring is all oversized as the old fridge was a monster. New one is a Seafrost BDXP air/water.
Graham
Graham and Janaki
Bristol 38.8
GrahamO is offline
post #6 of 16 Old 09-29-2013
Originally Posted by mitiempo View Post
This is DC so a main breaker is not needed......
Not sure what you mean by not needed. If you mean that separate breakers are not absolutely necessary to safely protect a circuit, I agree.
However, in the event of smelling an electrical fire (the most common form of boat fire), wouldn't you want one master switch to kill it all? In addition, if you're up on the hard or away or just need to kill all parasitic loads, a master is very helpful. That may not be a breaker, but often goes through a kill switch of some kind.
Jeanneau 54DS
post #7 of 16 Old 09-29-2013
One of None
deniseO30's Avatar
Size the breaker per unit specs.. 15 amp.. guessing again..
why is needed information always a secret with people asking for advice?
My last project!
post #8 of 16 Old 09-29-2013
mitiempo's Avatar
A main breaker is not needed because the house bank should be fused within 7" of the positive post. That fuse will protect the wire to the main switch and from there to the main DC panel, where each circuit has a breaker or fuse which it must have. Whenever the wire size drops a new fuse is required if the main fuse is below the ampacity of the smaller wire.
As I posted a sub panel or fuse block is often used for "always on circuits" like the bilge pump or refrigeration. I also said a switch can be installed to isolate the sub panel or fuse block if desired. It is a good idea but I rarely see it.
Brian
mitiempo is offline
post #9 of 16 Old 09-30-2013
Glad I found Sailnet
Bene505's Avatar
We use a dedicated fuse for the fridge, wired directly to the battery. Fuses cause less voltage drop than circuit breakers. Our fridge is always on.
Actually, our compressor is well aft, far from the house bank and right near the shore power charger. I use the (now disconnected) shore power charger's wire. It's 6 gauge. Then I have the fridge fuse coming off that, to a short-ish 14 or 16 gauge wire. 5 amps load. Seafrost says to make sure the compressor gets good power.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #10 of 16 Old 09-30-2013 Thread Starter
GrahamO's Avatar
Thanks Brad,
Do you have a switch that allows you to isolate the refrigerator?
Graham
Regards,
Brad
Graham and Janaki
Bristol 38.8
GrahamO is offline
refrigerator wavedancer38 Provisioning 15 02-03-2012 01:26 PM
Refrigerator billbalme Pacific Seacraft 7 04-11-2010 02:17 PM
Refrigerator jacobitesc Beneteau 4 02-24-2009 03:17 PM
main breaker rating adamtroyg Gear & Maintenance 28 04-13-2008 07:33 PM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
