Blue Seas terminal fuse block on a 5/16" battery stud? - SailNet Community
post #1 of 15 Old 10-06-2013 Thread Starter
I'm replacing my battery cables, and installing some fuses while I'm at it. I purchased the Blue Seas MRBF terminal fuse blocks, but was surprised to discover that they are sized to fit 3/8 battery terminals. My batteries have 5/16 terminals on both positive and negative, and I'm told that this is quite common. So is it acceptable to use this combination? Or do I need some sort of adapter bushing? Or something else?
Russ
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is online now
post #2 of 15 Old 10-07-2013 Thread Starter
Re: Blue Seas terminal fuse block on a 5/16" battery stud?
I'm thinking I might be able to use
http://www.amazon.com/Pico-Military-Terminal-Positive-Negative/dp/B001QRTZR0/ref=sr_1_1?ie=UTF8&qid=1381166808&sr=8-1&keywords=battery+terminal+clamp+military
which would allow the fuse block to sit on its side, reducing its height, or perhaps
http://www.amazon.com/Sea-Dog-415210-1-Battery-Terminal/dp/B000X9XSQG/ref=sr_1_20?ie=UTF8&qid=1381166993&sr=8-20&keywords=battery+terminal+clamp+marine
which would make the block sit even higher.
Thoughts?
post #3 of 15 Old 10-07-2013
Dirt Free
boatpoker's Avatar
Absolutely no wingnuts or nylock nuts.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 15 Old 10-07-2013
Maine Sail's Avatar
Russ
On a standard marine post one hole size larger is acceptable just be sure to put a flat washer on top and no wing nuts. If you don't need an adapter don't use it as it adds multiple connection points.
There are literally hundreds of thousands of battery terminations out there with a 3/8 lug on a 5/16 post.. Perfect? No. Deal breaker? No.....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 15 Old 10-07-2013
Maine Sail's Avatar
Please give us a reference and rational for no Nylocs....
______
post #6 of 15 Old 10-07-2013 Thread Starter
Now that's the cheapest and easiest answer of all. Thanks!
post #7 of 15 Old 10-07-2013
no longer reading SailNet
Alex W's Avatar
Bluesea claims that they are for 5/16" studs:
MRBF Terminal Fuse Block - 30 to 300A - Blue Sea Systems
My battery has M6 bolts instead of studs and I did use a washer as Maine Sail describes.
Alex W is offline
post #8 of 15 Old 10-07-2013 Thread Starter
[QUOTE=Alex W;1100709]Bluesea claims that they are for 5/16" studs:
QUOTE]
What they're referring to there is the size of the stud to which the cable is attached, vice the battery terminal. It's clearer in this diagram:
http://assets.bluesea.com/files/reso...91_drawing.jpg
But I'm good with the washer method if you all are.
post #9 of 15 Old 10-07-2013
Maine Sail's Avatar
Blue Sea recently changed the size of the fuse stud from 1/4" to 5/16". The hole in the fuse holder, that goes over the battery stud is still 3/8" as it has been since they launched..... Some retailers may still have the old 1/4" post versions...
______
post #10 of 15 Old 10-08-2013 Thread Starter
Turns out that a washer wasn't required, because I had to place a lug for a bank connector cable (which has a 5/16 hole) right over it anyway.
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
Fuse near the battery JacobI Electrical Systems 9 04-17-2012 01:10 PM
Cable size for fuse block? SanDiegoChip Electrical Systems 10 11-14-2010 11:20 AM
Battery terminal post melted? Anyone seen this b4? nicferrante Gear & Maintenance 30 05-02-2009 12:21 PM
Terminal block shantijwk Gear & Maintenance 3 02-20-2007 04:57 PM
