mount battery in bilge floor? - SailNet Community
 8Likes
post #1 of 14 Old 10-17-2013 Thread Starter
When i got my boat the battery and fuel tank is in the bilge under the cockpit floor. They battery tends to slide around down there in its plastic battery box. Would 5200 or epoxy be enough to glue the bottom half of battery box still or would it not hold the heavy battery in a damp area?
HighCs123 is offline
post #2 of 14 Old 10-17-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: mount battery in bilge floor?
More info please. What type/size of boat. What type of batter, gel, AGM, wet?
But up front, the battery should NOT be loose and slip around! That is very dangerous.
If it were me, I would not try to glue the box down. It needs some sort of structural hold down.
Greg
Faster and 34crealock like this.
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #3 of 14 Old 10-17-2013
Greg is right.. structural location, and protection against falling out of that 'box' in the event of a knockdown. (Tie down/top strap etc)
Faster is online now
post #4 of 14 Old 10-17-2013 Thread Starter
Marine battery. Siren 17'. Battery box secures battery with a lid. Just curious if epoxy would hold it since there is nothing to screw it into. My original idea was to fiberglass a pice of 3/4" marine wood onto bilge floor and screw box onto it. boats are often built with epoxy and 5200 replacing screws so thought it may work for a battery hold.
post #5 of 14 Old 10-17-2013
The smooth plastic of a battery box is not a good candidate for any kind of adhesive.. I'd be much more comfortable with building an appropriate box and gluing IT down with 5200 (with the hull surface properly prepped, of course).. then securing the battery in that.
jimgo likes this.
post #6 of 14 Old 10-17-2013
Delezynski's Avatar
From my point of view.......
Short answer, epoxy or 5200 will NOT stick well to a proper battery box. Go with the marine wood and screw to it. Just don't screw down into the wood. Seen many people hole a boat drilling/screwing down into something....
Greg
Home page -
Youtube page -
post #7 of 14 Old 10-17-2013 Thread Starter
This was my suspicion as well. Thanks for all the input.
post #8 of 14 Old 10-17-2013
How about glassing in a wooden frame around battery box with eye bolts built in. That way you get horizontal motion secured and lashing down for extreme boating fun.
miatapaul and jimgo like this.
Capt Len is online now
post #9 of 14 Old 10-17-2013
asdf38's Avatar
I wouldn't recommend it as good practice, but if I was going to "glue" a plastic box down I'd be using 3M VHB tape. It's incredibly strong, easy to use and you know it can be sliced away with a putty knife.
asdf38 is offline
post #10 of 14 Old 10-18-2013
Glue a piece of marine plywood, coated with penetrating epoxy, to the bottom of the bilge. Paint it, if you like and if the bilge is painted. Then attach a real strapping system or hold down to it.
L124C likes this.
Jeanneau 54DS
Minnewaska is offline
Radar - Stern Mount or Mast Mount night0wl Gear & Maintenance 34 03-19-2009 07:00 PM
All of a sudden - A Bilge Smell, and Battery Issue labatt Gear & Maintenance 19 10-09-2008 10:04 AM
Need material to raise floor of bilge slightly saltypat Gear & Maintenance 5 09-20-2007 07:30 PM
Bilge Pump Failed, 6" Water over floor, what now? psolson Gear & Maintenance 33 09-07-2006 04:26 PM
Using "Starboard" for bilge pump mount? mikeedmo Gear & Maintenance 11 06-13-2006 06:43 PM
