Solar Battery Charging - SailNet Community
post #1 of 5 Old 10-18-2013 Thread Starter
casey1999's Avatar
My boat has two 80 watt solar panels (total 160 watt) that feed a charge controller. This charges the 225 amp hour AGM house battery. That all works fine.
I also have a Costco starting/deep cycle lead acid battery I use to start the engine (this battery is new). The engine alternator will charge this battery.
The house and engine start battery can be connected together via a battery switch. When the engine battery started to go bad, I could start the engine using the switch which would connect the house and start batteries.
Since I have no trickel charger on the engine battery, can I leave the house and engine battery connected to keep a full charge? I understand the charge characteristics between the batteries are different so not sure if this is a no no. I do see that the charge voltage for the house AGM battery is 14 volts or more- this seems high, but all has run well for 6 years so assume all is well.
casey1999 is offline
post #2 of 5 Old 10-18-2013
Re: Solar Battery Charging
Yes, you could do that, but it's not the optimum solution.
AGM and flooded battery charging profiles are almost identical, so no problem there.
However, in the (somewhat unlikely but not impossible) event that a short developed in either battery bank, or a load was inadvertently left on (bilge pump continuous running?) you could flatten both banks.
A better solution is to use a voltage follower device like the Xantrex EchoCharge or the Balmar DuoCharge to keep the starting battery topped off.
These devices work by sensing a charging voltage on the house batteries and, when it is present, drawing off enough current to just top off and maintain the start battery. All automatic. No switches required. You don't have to remember to switch anything.
In your situation, the EchoCharge would be appropriate. It costs about $140 and is very easy to install. Mine has worked 24/7 for the past nine years, and I've installed a bunch of them on client's boats....all without issue so far as I know.
IMHO, these devices are better than "combiners" because there are no mechanical relays to go bad and they allow regulated current to flow in only one direction: from the house batteries to the start battery.
Keep in mind that the typical start battery requires VERY LITTLE CHARGING to keep it topped off. But, flooded LA batteries do need to be kept at a high state of charge to slow the sulfation process.
BTW, both AGM and flooded batteries like to be charged at over 14 VDC. Lifelines like 14.4-14.8VDC, while the Trojan T-105s like 14.6-15.0VDC during the absorption phase. I assume you have a smart controller for those panels?
Bill
btrayfors is offline
post #3 of 5 Old 10-18-2013 Thread Starter
casey1999's Avatar
Bill
Aloha and thanks for that great information.
Yes the AGM battery is charged by a Xantrex C series charger. It seems to work well, but is not water proof. So far no water damage. The charger does not have the battery temperature monitor included, I could easily add it if needed.
post #4 of 5 Old 10-18-2013 Thread Starter
casey1999's Avatar
Another thought,
What about installing say a 20 watt solar panel and just connect directly to the engine start battery to keep topped up (no charge controller). Would that be ok?
post #5 of 5 Old 10-18-2013
mitiempo's Avatar
Originally Posted by casey1999 View Post
Another thought,
No. you need a controller. The battery voltage without one will be too high.
I like Bill's Echo Charge solution, I install many as well without problems. Ideally I would change the alternator output to the house bank - and any other charge sources as well. That way all batteries will be fully charged automatically.
Brian
mitiempo is offline
solar charging problem - troubleshooting help please! copacabana Electrical Systems 20 04-15-2013 04:17 PM
24v solar panel for 12v charging? Bene505 Electrical Systems 7 01-04-2012 10:44 PM
New davit with wind and solar charging dsbentley Gear & Maintenance 17 08-03-2006 11:33 AM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 09:00 PM
Charging with a Solar Panel Sue & Larry Gear and Maintenance Articles 0 11-22-2001 08:00 PM
