solar panel fix? - SailNet Community
 2Likes
post #1 of 11 Old 12-06-2013 Thread Starter
christian.hess's Avatar
solar panel fix?
hey guys this is my panel...it was in the boat from the previous owner...works fine
and:
anybody got some solutions on how to reseal the edge and maybe what glue would work nicely and not damage the cells? its seems to have from the factory a black polysulfide or polyurethane type sealant...
I will redrill and rivet the aluminum frame or just JB WELD it with a strap of metal...
thanks
christian.hess is offline
post #2 of 11 Old 12-07-2013 Thread Starter
Re: solar panel fix?
anyone?
guess any sealant will do then....
post #3 of 11 Old 12-07-2013
Christian, it's hard to see exactly how big the problem is from your photos (at least for me). I would try to "tack weld" everything in place with thickened epoxy and then seal with polysulfide sealant. It might not look beautiful, but I think it would keep the water out and protect the electrical thingies.
christian.hess likes this.
Vindö 50
copacabana is offline
post #4 of 11 Old 12-07-2013 Thread Starter
thanks yeah its half the frame that is loose from the actuall panel...its attached with the black looking sealant
the frame has 2 screws that broke off...
the black box where the wires are is sealed and cleaned up...
I really was just wanting to know if any black sealant we commonly use would be ok
sorry for the pics they are a but too close up
post #5 of 11 Old 12-07-2013
I've had great luck with Sika 295UV. What are the common brands in El Salvador?
Vindö 50
post #6 of 11 Old 12-07-2013
mitiempo's Avatar
Copa
295UV requires a primer. I doubt it is available there.
Christian
I would use an angle bracket to put the frame together and keep it there as you posted. I wouldn't use epoxy as I don't think it will work well - epoxy doesn't stick to plastic and the back side of many panels are plastic. I would use something like the adhesives found at Home Depot like Dap or failing that 5200. You won't be taking it apart ever anyway. With a tight frame it doesn't have to be very strong.
Brian
mitiempo is offline
post #7 of 11 Old 12-07-2013
You don't "need" to use a primer with 295UV, but Sika would love you to use their absurdly-priced primer.
Vindö 50
post #8 of 11 Old 12-07-2013
mitiempo's Avatar
Especially if you want it to work well.
The job doesn't require an expensive sealant - any good one should work. 5200 if available is a good choice.
Brian
mitiempo is offline
post #9 of 11 Old 12-07-2013
Not to labour the point, but I don't think any other structural silicone adhesive or bedding compound (Dow Corning, 3M, Boat Life etc.) calls for a primer. Sika recommends using their primer for best results, but when you see the price of a micro-sized tin of primer your hair will curl. FWIW, I've been using it without the primer with no problems.
I do like your idea of using aluminium angle to hold the frame together. Perhaps with rivets.
Vindö 50
post #10 of 11 Old 12-07-2013
mitiempo's Avatar
Rivets or 10/24 machine screws would work well. I think from what Christian has said most marine sealants are expensive where he is.
Brian
mitiempo is offline
solar panel QuickMick Gear & Maintenance 15 01-18-2016 04:36 PM
Solar Panel Magnolia Electrical Systems 8 08-19-2013 08:40 AM
solar panel MarkusM Gear & Maintenance 7 02-17-2013 12:41 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 11:02 AM
Solar panel ldbarker Gear & Maintenance 3 10-27-2002 01:31 PM
